Results 1 to 15 of 15
    Feb 2010
    I have a toyota corolla 92 model gli
    what could be the possible cause if the fuel injectors have no power supply???
    and where should i put the ground of fuel injection valve....
    tnx a lot...
    Feb 2009
    Quote Originally Posted by wormsarm21 View Post
    tnx a lot...
    the fuel injectors receive voltage through a fuse, they are grounded on pulse width modulation from the ecm (pcm). circuits 10 and 20 that pulse ground the injectors are called drivers. check your fuses first
    Feb 2010
    thanks a lot sir.... so it doesn't mean you can ground it to the engine block or elsewhere?
    is the fuse located under the hood? or on under the dashboard in the driver seat....
    Feb 2010
    Tinignan ng mekaniko kanina un kotse... nilipat un ground ng fuel injection sa intake manifold,ni check din un fuse sa ilalim ng dashboard sa driver seat.
    it could be a computer box problem???
    need your help...
    Feb 2010
    Could be a problem in distributor if the fuel injector has no power supply?
    Jun 2005
    malamang injector. bili ka surplus sa banawe. 800 lang pang sr20 kaya mas mura dapat para sa 4afe.
    Feb 2010
    Sir may idea po ba kayo kung magkano un surplus na computer box ng 4A FE....
    Narerepair po ba un computer box? Magkano po kaya
    Feb 2009
    your situation as you stated has no power to the injectors. in this case, the problem is not the pcm nor the injector. listen to your question.
    email direct for an answer not a guess
    Feb 2010
    Sir un nga po problema, wala power supply po dun sa fuel injector, nag try na po magpailaw ng test light dun sa supply, di po umilaw.
    Apr 2011
    hinde basta basta nasisira ang computer box,..try to check muna lahat ng fuse or wiring line mo,..better to go with car auto electrical shop,..hinde sa car mechanic kung electrical ang deperensya
    Feb 2009
    Quote Originally Posted by trojanvirus79 View Post
    that's exactly the difference between the technician from the mechanic. cars have been complex machinery, one needs a good knowledge of hydraulics, electrical, computer controls, a little bit of chemistry and a sizeable knowledge of physics and geometry. mechanics are getting obsolete very fast
    Feb 2010
    Salamat sir sa mga response, nag try kame ng ibang computer box, yun umandar sya, so it means computer box may problem
    ngayon need ko lang advice nyo kung ano mas mainam, bumili ng surplus or ipaggawa??? la na sa isip ko un brand new masyado ng mahal, tnx. 4A FE nga pala un makina ko.
    Apr 2011
    pa check mo rin yung ibang mga wiring baka grounded na ,..sanhi ng pag kasira ng computer box..kung sira nga yung computer box mo ,..pagawa mo muna sa electronic shop like pagawaan ng tv, dvd audio video,..kaya nila i diagnose yan,..malay mo capacitor lang pala sira,..naka mura ka pa
    Feb 2009
    the injector drivers inside the pcm might have overloaded. have the injectors tested of resistance. they might be partially shorted or their resistance lowered causing the npn transistor injector drivers to break.
    Feb 2010
    Sir baka may kilala kayo ng home service na Auto Electrician.... Pateros Area ako.
    Tnx
Fuel Injection Ground
