Results 1 to 9 of 9
- Dec 2002
- 16
October 16th, 2003 07:44 AM #1Tsikot peeps, need your help here. My car is AE101 toyota. Last sunday, i disassembled my panel gauge to clean up pero di ko tinanggal yung mga needles. After cleaning, the temp , speedo, and rpm gauge work fine pero yung fuel ay nagloko. Before disassebly, the pointer is at 1/4 but after cleaning, it goes higher than 1/2 and it stays there. Nagkarga ako ng gas worth 500 from shell, tumaas siya hanggang full. nakakatakbo na ako about 86KM pero di pa rin bumababa. ANo kaya problema nito? need your inputs... Thanks a lot...
- Dec 2002
- 16
October 17th, 2003 05:36 PM #3
The spring could be stuck. Try taking out the gauge cluster again and give it a vigorous shake.
BANNED BANNED BANNED
- 3,790
October 20th, 2003 05:01 PM #4baka mayroon needle "zero" adjustment yung gauge at nagalaw mo....the fuel gauge is a voltmeter/resistance meter kasi and it does have a "zero" adjustment somewhere for calibration purposes.
- Dec 2002
- 16
October 31st, 2003 02:30 PM #5I've tried taking it off again pero wala naman siyang zero adjustment, wala din siyang spring.
October 31st, 2003 03:31 PM #6
di ba nabaluktot yung needle? ginawa ko na yan dati kala ko nasira ko. yun pala tumatama yung needle sa salamain umangat pala sya.
- Mar 2007
- 18
- Sep 2014
- 2
September 13th, 2014 10:32 PM #8i encountered same problem up to now wala pa din nakakaayos ng fuel gauge ko. Nauubos lang pera kakapa check up kung saan saan. Meron bang shop na nakaayos ng fuel gauge nyo? Pati park n' fly hinde nagawa problema ko dito.
- Sep 2008
- 295
September 14th, 2014 06:51 AM #9Happened to me. It turned out kinagat pala ng aso namin yung wire ng fuel tank sensor kaya laging nasa empty.
Daming issue ng SU7:grin:
Xiaomi E-Car
