Results 1 to 14 of 14
    Jul 2006
    I had my car's indiglo gauge change at ****LINE makati...then I noticed that my fuel gauge is not accurate as it was before I changed my indiglo gauge...Since I know the gas consumption of my car I am quite sure that if i travel from point A to point B I know the needle on the fuel gauge will drop to a certain point..but hell no it just moved down a bit..but when I got into the car the fuel needle dropped dramatically..
    Just like yesterday..the gauge reads it still has 10% of it then I went to a gas station and add 100 petot of gas since its just a short trip..and I noticed my gauge went up +30%..and the weird thing is I traveled far knowing that an additional 100 petot of gasoline will not take me..
    It scares me that if I drive for a long distance my car would just stop in the middle of the road because it does not have gas anymore..
    At first I really thought it just need some time to calibrate itself...but after 2 mos its still the same..I want to suck empty the car's tank so i would really know if the reading is accurate..
    I need help from you guys..please advise what to do..TIA!
    you should have brought your car back to where you had your gauges changed the first time you noticed your fuel gauge isn't pointing at the right fuel level.
    Jul 2006
    I am from pampanga..and I just come to manila when I have an important business to attend to or when I go to a certain autoshop to buy some accessories or to check the car out..and also i won't go back to that sh***y shop anymore...all they advise you is to replace...actually they don't advise he will just ask you to palit or not..if not then go away..
    Anyway is there anything I can do?or any alternative solution for this..TIA
    tnx boybi for the reply..
    by saying that you changed you indiglo gauge, did you mean you changed the whole instrument panel? if yes, does it have warranty? if it have warranty, then, to avoid additional expenses, you really should return it to your shitty shop.
    Jul 2006
    just the face not the whole instrument panel..sorry for the confusion..
    May 2005
    baka nag nag install ng indiglo lights/gauge.
    .nagalaw ang needle (nabatak ang springs)
    kaya nawala sa tamang tension ng spring at di na nabalik tamang position ang needle kaya di na accurate magbasa
    Jul 2006
    me solution pb ito?baka nde ko alam sa reserba na lng ako tumatakbo..
Fuel gauge not ACCURATE?! > need help!
