Results 1 to 5 of 5
May 30th, 2015 04:38 PM #1
Mga sir ask lang po OK lang po ba na naka hang yung wire sa baba ng fuel filter at para saan po ba yun mga sir? thanks
- Aug 2013
- 475
May 30th, 2015 05:01 PM #3ganito din yung sakin. hindi na kasi nawawala warning light kaya hindi ko na kinabit.
problema lang sa ganyan, hindi mo malalaman kung may water contamination na fuel filter mo.
toyota 2L naman yung sakin. same sa picture mo.
May 31st, 2015 12:14 PM #4
yung wiring na nasa baba ng filter assembly ay para sa indicator na madami nang water na na-trap sa filter... as the water settles at the bottom pag dumami na tubig aangat yung float inside at didikit sa isang wire sa body, magkakaroon nang signal and will light up a warning sign sa dashboard.
pwede ikabit, pwede din hindi. pero some models will have the warning light on pag di nakakabit, some others wala naman. kaya its up to the user. kung hindi niya ilkabit dapat regular palitan yan, every year would be good..
June 10th, 2015 11:21 PM #5
Somewhat expected from a rushed car from a first time carmaker
Xiaomi E-Car
