Results 1 to 4 of 4
    guys tanong lang..
    ano ang normal na pasok ng gaso sa fuel filter??
    ung sa akin kasi parang gripo sa lakas. feeling ko lumakas kumain ng gaso ang makina. d naman ganun dati un pero bigla na lang sya. sa fuel filter kaya??
    one more thing, ayaw bumaba ang menor.tried iikot na ung screw pero d nagbabago. ano kaya ang rason?? dinala ko na sa mekaniko pero sabi nya normal naman at wla naman problem. ok naman ang hatak ng kotse ko ngaun.
    ride is 93 corolla xl.
    Malakas talaga pasok ng gasolina sa fuel filter. If it was clogged, performance would suffer. It can spray you in the face if you're not careful.
    the fuel filter is placed between the fuel line from the gas tank to the engine, so talagang malakas ang pasok nyan. it is because the purpose of the fuel filter is to ensure that the fuel going into the engine is clean or is free from elements so it can give a complete burn.
    with regards to your carb problem, di ko alam.
    Nov 2003
    normal lang yan... magtaka ka kapag mahina na yung pasok ng gas.
fuel filter question
