Ask ko lang sana kung may recommended na autoshop dito pasig na nag hohome service. Ang nangyari po kase yung 1997 corolla ko nagkaproblem sa clutch minsan nawawala so dinala ko sa Petron and they replaced the secondary clutch master kase daw nag leleak naging ok po sya then after 3 weeks ayun bumalik yung issue to the point na need mo na patayin makina para lang matanggal yung clutch.
Since may iba naman ako sasakyan pinabayaan ko lang sa garahe now last week when i try to start it again namamatay na yung engine pag binibitawan yung gas as in derecho 0 RPM then kanina umaga redondo na lang ayaw na mag start.
