Page 1 of 2 12 LastLast
Results 1 to 20 of 21
    Apr 2009
    Ive noticed that the paint on hood on the center part keeps fading. Does it have anything to do with the engine? Might be too hot? Corolla 1997 gli 1.6 here.
    Sep 2009
    Quote Originally Posted by bail View Post
    Ganyan din sa kin- repaint na yan tapos papalitan mo na yung anti-heat matting sa loob ng hood.
    Quote Originally Posted by jkatzify View Post
    normally nangyayari yan pag manipis na ang coat of paint or luma na ang paint.
    kung bagong pintura, it could be that the paint is not properly cured or not properly layered.
    tama ang solution, put an insulator below the hood. it helps.
    I'm also bewildered by this, I personally haven't experience hood paint fading in any of our vehicles. Either vehicles with or without hood insulation.
    Seen that so many esp those without covered parking. Trunk and roof fades.
    Jul 2015
    Di ba kaya ng rubbing?
    Aug 2012
    Lalo mag fade yan if i-rubbing mo. Rubbing compound will remove paint. Repaint lang ang solution as mentioned above.
    Sent from my D5833 using Tapatalk
    effect na din siguro iyan ng years of constant exposure sa uv rays. ang colors na may shades of red pa naman ang pinakamabilis o mas prone magfade kapag matagal na tinatamaan ng hagupit ng uv rays
    May 2012
    Hamog sa umaga yan na natutuyo pagsikat ng araw, nagiging stain na magaspang hanggang mag fade.
    Try mo ipolish kung matatangal pa if nandun pa din repaint na yan
    Jul 2015
    Quote Originally Posted by red_one View Post
    Try using meguiars ultimate compound
    Nov 2014
    Di ba too far gone na yung paint for rubbing compound? Kasi parang faded na talaga. Unless what I'm seeing is something like oxidation on top of the clear coat.
    Jul 2015
    Quote Originally Posted by kai s. View Post
    He can chk a portion kung pwede pa kuya
    Aug 2012
    It's a 19 year old car. It's about time to repaint the hood.
    Nov 2014
    19 year old car -- washover na
    Aug 2012
    True.
    Apr 2009
    Thanks for the replies. Washover and repaint the same lang ba?
    Aug 2012
    In a way. Washover means repainting the whole exterior of the car. Repaint can be per panel, part or the whole car.
    Oct 2014
    Other possible work around if ayaw mo repaint is palitan mo ng carbon fiber yung hood or patungan ng carbon sticker.
    Nov 2014
    CF hood:
    CF sticker:
    Aug 2012
    Pwede rin foil wrap on hood. Matte color.
Fading paint on hood
