Results 1 to 18 of 18
    Apr 2009
    Na observe ko after changing my oil from 20w50 to 10w40 and also from bosch platinum spark plugs to OEM spark plugs, fuel consumption ko naging 5km/liter na lang. bago din naman ang air filter. car is 1997 corolla 1.6 gli with 123k mileage. Ano kaya ang problem?
    Jul 2015
    Quote Originally Posted by bail View Post
    ilan ba dati? 6? if its an AT, better chk the tranny fluid...
    Apr 2009
    dati is 8km per liter. manual transmission
    other symptoms?
    Jun 2011
    Check tire pressure..
    Aircon compressor bearing/ pulley bearing
    Rear brakes/ Handbrake cable
    Check for fuel leaks
    Check- aircon aux fan/and condenser...
    Check your car aircon for high pressure
    And Balik mo lahat ng ginagawa or pinalitan mo dati...like oil.. spark plus etx.
    Mar 2004
    Maybe engine needs a tune up? ...
    Aug 2013
    kung humina hatak ng makina sir, possible nabawasan compression dahil sa mas manipis na oil na ginamit kaya lumakas fuel consumption.
    Apr 2012
    Quote Originally Posted by innova2013 View Post
    maybe its the other way around. baka gumanda hatak ng makina since manipis oil na ginamit kaya naging mas aggressive driving style ni TS at tumaas fc
    seriously, TS just get back to the old oil and spark plugs. using thinner viscosity oil may not be that good to a 20 year old engine seals..
    Long shot, - sparks bro.
    One of our rides was doing 8km/L for a long time.
    I changed spark plugs.. went down to 7Km/L
    Check mo dipstick kung nababawasan ng langis or check mo tambutso kung meron na kaunting usok lali na pag dinidiinan yung gas pedal. Pag positive pareho ang dahilan nyan ay yung paggamit mo ng manipis na langis. Dahil medyo luma na, maluwag na yung mga piston ring at sumusuot na yung langis sa compression chamber. Kasama na sya nasusunog dun at hindi na tuloy maganda and air-fuel mixture kaya mababa na efficiency ng makina.
    Apr 2009
    natawa ako dito may point ka nga sir kasi gumanda nga talaga yung hatak nung pinalitan ko to a thinner oil. ano yung may not be that good to my engine pag thinner oil? ano mangyayari? So change back to old oil kahit pangit ang hatak nun?
    Apr 2012
    since gumanda hatak, na-enjoy mo umapak sa gas pedal so your usual driving style and fc changes too kung old na engine, old na rin mga oil seals. it's a common notion na when you use thinner viscosity oil may tendency magkaleak sa mga oil seals.
    Apr 2009
    Quote Originally Posted by Wishing View Post
    yung oil ang nabawasan and may konting leak around sa valve cover gasket. dati nung nasa 20w50 ang oil wala siyang leak.
    Apr 2009
    actually kakapalit ko lang din ng camshaft and crank shaft oil seals and also yung seals around the spark plug. So mas ok bumalik na lang sa 20w50?
    Apr 2012
    i see, no worries pala at bago mga seals. if you are not comfy sa FC now then you can go back to your old oil in your next oil change.
    Jun 2008
    Tama ba ang specs ng spark plug na kinabit?
    Sent from my NX549J using Tsikot Forums mobile app
    Jul 2013
    I'm guessing timing ang may problema.
    Pacheck mo sa service centre na kaya mag check/adjust ng ignition.
    Sent from Zenfone 3 on Tsikot mobile app
    May 2011
    With that mileage, the timing belt should have been replaced already. If it was not, chances are the timing belt has stretched causing late valve timing or the timing belt has skipped a tooth or two. Verify correct cam timing using a vacuum gauge. The vacuum should be between 17-21 in.Hg. preferably around 21 in.Hg at idle speed.
    There is a possibility that the exhaust is partially restricted. The exhaust back pressure should not exceed 1psig measured at the oxygen sensor mounting.
Fuel Consumption is 5km/liter
