hi, anyone out there..... engine won't catch, checked fuel delivery lines no supply, suspect engine shut off switch is stuck in off positiion, any other issues i should look into? Thanks guys
Check your fuses and loose / corroded harness connectors. And don't apply 12 volts to any part of the injection pump harness. These are the only things you can do.
Go to a certified service center. Avoid bringing it to just any mechanic. Ingat sa murang mahal! Mura ang estimate pero dahil nasunog lahat ng electronics lalabas na napaka mahal.
