Results 1 to 5 of 5
- Oct 2008
- 469
February 23rd, 2010 11:43 PM #1Sabi sakin ng mechanic my singaw daw sa Exhaust Manifold ko, kaya medyo hirap talaga ako sa hatakan. Parang naririnig ko kasi after ko bumitaw sa 5th gear, my air leak ako naririnig sa pipes or sa exhaust. may possibilities po ba na kaya medyo hirap sa hatakan and malakas sa gas is because there are some leak in ExhaustManifold? Nahihinang or narerepair po ba mga ito?
Ride: Sentra B13
Thanks Tsikot
February 23rd, 2010 11:58 PM #2
Depends on where the leak/crack is located.
If its the exhaust gasket, a simple replacement job would fix it.
If it's the stock exhaust manifold, you will have to replace it because you cannot weld cast iron. Your choices would be a surplus stock exhaust manifold or a set of headers.
- Oct 2008
- 469
February 24th, 2010 12:17 AM #3
February 24th, 2010 01:15 AM #4
- Oct 2008
- 469
February 24th, 2010 06:26 PM #5
alas, much as we might want to rely on our noses, we may not use our noses to do emissions...
LTO accredited emission testing centers
