My daily drive is a Honda Civic 1.8S A/T and it's been with me since January 2008. Since new, I've always had the oil replaced at or around every 6 months. Why? Well, the manual states that the oil change interval should be every 10,000KM or 6 months, whichever comes first. Since my drives are 90% stop and go or bumper-to-bumper city driving with the heat, dirt, pollution and all, and spending a lot of time with the engine on idle, these were considered as Extreme Conditions as per the manual. As such, I was pretty religious with the PMS (done mostly at Honda SPA).
But as with anything mechanical, there will always be wear and tear. In my case, it came in the form of the two rubber O-rings sealing the VTEC valve and the plastic valve cover, respectively. The O-rings have become brittle from the heat of the engine. As such, the engine recently started to leak motor oil. It's a minor problem and all that was needed was to replace the two O-rings. This meant removing the plastic valve cover and the VTEC valve.
Long story short, I was able to have the O-rings replaced but what got my attention was how clean the inside of my engine is. It's already nearing 7 years with about 70,4xx KM under its belt. Yet, the inside still looks new. Even the mechanic made a note of how clean it was.
My R18 engine with the valve cover off:
By comparison, here is another R18 engine with sludge buildup due to neglecting to change the oil as prescribed:
Sludge on R18A, orangehonda.tumblr.com - YouTube
Here's another link about the subject matter: http://orangehonda.tumblr.com/post/9...nce-from-first
In summary, preventive maintenance is not always about service centers ripping you off. If done right, it WILL significantly extend the life of your car. The reason I always go to Honda SPA is that they allow customers full access to their cars even while it's up on a lift (at your own personal risk, of course). You're also allowed to interact with the mechanics actually fixing it. These technicians have seen it all and you can stand to learn a thing or two about your car ordinary people don't know about.
And also, don't skimp on quality fluids, especially on a Honda. I know it sounds like a marketing thing but I personally believe that there's really something to it. Anyway, I always use Honda Fully-Synth 5W40. Once, I tried the Honda 0W20 "Green" motor oil but I didn't liked the engine response. I think our weather is way too hot for a '20' weight oil. I also use Honda PSF for the power steering, Honda ATF-Z1/DW1 for the automatic transmission, and Honda Type-2 (NOT Type-1) Coolant well, as coolant. I don't allow equivalents/substitutions where fluids are concerned. So far, this has rewarded me with a relatively trouble-free drivetrain.
DISCLAIMER: I am NOT in any way, shape, or form, affiliated with Honda, Honda Philippines, or any Honda Service Center. I'm just your everyday car and all thingamajig enthusiast.
