Results 1 to 10 of 10
- Mar 2009
- 1
March 19th, 2009 06:07 PM #1hi im leny just got a liteace toyota van 1991 model (Converted) (un po kc kaya ng budget ko...O)
1 month lady driver...hehehe im planning to change oil this april yun ksi sabi nung manong mekaniko sa shell... i read some of the threads here cooooooolll naman got some info peo ask ko lang ano ba maganda oil gamitin ko for my van? diesel and A/T po my van. hope you could help amd ok lang ba kung sa shell na rin? thanmks a lot
March 19th, 2009 06:15 PM #2
ok lang din ang shell. sabay mo na din palit ng AT fluid. dun na din sa shell.
March 19th, 2009 06:32 PM #3
sa Shell dito sa amin (tuazon ave. marikina) okey ang service and mura labor saka mabait mekaniko ... hanap mo si loloy yun madali kausap saka masipag hindi mo na sasabihan i check ang kailangang i check may kusa .... HTH
PS ' may diesel pala na liteace?
- Sep 2007
- 110
March 20th, 2009 07:58 PM #4helo mam, kung magpapalit po kayo ng atf (automatic transmission fluid) make it sure na tama po ang atf na ilalagay. baka kasi donax ang ilalagay na atf ng shell sira sigurado ang transmission mo. i'm not familiar kung anong atf ng liteace you can check it sa net kung wala kayong owner's manual. congratz on your new ride.
March 20th, 2009 08:20 PM #5
*kenzie: oo meron, mga galing japan
*miss lheny: ok naman po ang shell. ano po habol ninyo, mineral, semi-synthetic, or fully synthetic? pero shell oils, ok naman po siya
March 21st, 2009 02:22 AM #7
welcome po sa tsikot.
I could guess It's a 2CT or 3CT engine. 4x4 ba?. I have posted some specs of 2CT in here: click
for Oils, you can go from 10w40(diesel) to 15w40(diesel). make sure you change Oil+filter every 5000km. for the Oil filter, go for Nippon oil filter brands if you want to save big time...
some tips:
1. have the Air filter Changed. mura lang yan, 250 pesos more or less (then have it changed on it's schedule...
2. make sure you put coolant mix on your radiator. these aces have reputation for overheating.
3. the ATF is dexron II (or Dexron III), make sure when you have it changed, palinis mo rin yung Strain/filter and the magnet located at the atf pan...
4. when the time comes for overhaul (hopefuly not soon), make sure the mechanic knows the right valve clearances. the in and out clearances are different... the clearance specs are posted on the link too...
kenzie: PS ' may diesel pala na liteace?
- Mar 2009
- 5
March 28th, 2009 02:43 PM #8try mo CITGO Citgard 500 15w40 for diesel engines, you can get them by Magallanes at BMG bldg.
March 28th, 2009 08:19 PM #9
my opinion is that engine can take anything, even delo monograde, hehe (i ran this oil in my pajero 4 years ago).
have no fear, shell oil is good. mahal lang ng konti.
Did some independent research and decided to go with the white pearl crystal.... para maiba naman. ...
