Results 11 to 12 of 12
Toyota is my choice
- Aug 2005
- 2,063
April 23rd, 2006 07:21 PM #12
redondo pero di tumutuloy - usually ignition coil/carbon, weak battery, faulty alternator, faulty fuel pump or worse dead computer. wag na natin siguro isama yung walang gas
ako ang usual procedure ko would be:
1. check if i can honk horn, turn on lights - weak (battery problem), if ok ignition coil (hanap electrician hehehe)
2. bahala na si electrician - he checks battery, alternator kung nag cha-charge, fuel pump, fuel tank
3. if everything is ok naman and the car has a computer yun na malamang yun - iyakan na mahal eh
hope this helps
You just unregister the device where its currently installed.
National ID Law
