Page 1 of 2 12 LastLast
Results 1 to 20 of 22
    Jan 2004
    Nag pa engine wash ako, after that, parang nag-iingay na yung makina (hindi lang sa belt, but i dunno, naglagay na ng grasa sa belt pero maingay pa rin).. parang tunog sa mga taxi.. irritado lang ako sa tunog. Ano kaya ang mga causes nito?
    Also, nadaan ako sa mataas na baha ako sa Pureza last dec 29 (night). di naman ako tumirik (kaya nag pa engine wash ako, amoy kanal ang makina), pero worry ko lang kasi parang may nag ingay na (and got worse nung nagpa-engine wash ako).
    hindi naman ganito kaingay nung last na nagpa-engine wash ako
    Car: Pizza 97 GL carb type.
    Thanks in advance.
    May 2004
    Buti Nagingay lng car mo. ako nagpa-engine wash hindi na nila mapaandar car ko....sa shell ako nagpacarwash. try mo patingin alternator mo.
    Mar 2003
    it could be the bearings inside the belt pulleys. usually, nawawala rin yung tunog after a few days. ganyan talaga after engine wash lalo na kung sa mga gas station. if the irritating sound continues, have the bearings inside the belt pulleys checked. they may need replacement.
    yung mga nag engine wash eh tinamad po iyan, they don't usually cover the alternator, di na lang daw nila babasain???!! labo nila hehe..
    check also the compressor, baka isa rin sa nag-iingay... nung nagpa-engine wash ako dati eh nag-ingay compressor ..ayun palit ako bearing..
    nakoo..ingat po tayo sa ilang mga gas station...majority gamit nila kerosene instead of degreaser which is harmful to rubber parts under the hood such as hoses.
    Apr 2004
    ok lang po mabasa ang engine. Yun mga electricals lang naman ang delikado mabasa. As for the ingay, for sure yun fan belt mo yan. Normally kse its a bit wet by oils coming from the engine, then you washed it out so medyo dry yun. Spray a liitle it of wd40 then observe it if its still there, yun mga bearings mo needs regreasing. Pero check your Oil Stick if may bubbles after running, it could be sign of Water mixing with oil. yun medyo malala na yun pero if that happens you will notice na babagal engine mo (malapit na kuma2k) hehehe... if all doesn't work let a mechanic chk your engine.
    Jan 2004
    ganun ba sync? di ko alam eh.. irritable lang ako sa tunog.. yung dati walang ingay.. as in okey na okey ang makina.. then parang ngayon, parang pag may sipon at ubo ka, iba yung tunog ng boses. parang ganun yung makina ko. check ko naman yung oil.. okey pa naman.. pero baka pa-tune up ko na rin.. kakainis.. lintek kasing baha yan eh. nangamoy kanal yung makina kaya naisipan kong pa-engine wash..napasama pa ata.
    anong klaseng ingay? yung tiping may kasamang nginig? kung ganun... try mo po patangal yung spark plugs... then linis yung area.. pahangin mo... yung putas ng plugs...para matuyo.. then pa timing mo uli...
    btw.. wag mo po lalagay grasa belts mo... sabon pwede.. para ndi dumulas yung belt po sa pulley.. sabon na may tubig.. konti lang... ipasayad mo lang po sa belt... gawain ko din po yan dati eh.. linalagyan ko wd40 yung belt pag maingay.. hehe..
    lesson of the day:
    avoid "wet" engine washes... this is cheap compared to engine detailing but the results too may damage your engine...
    May 2004
    Almost a year na na nailusong mo sa baha (Dec. 29) ngayon mo lang narinig ung ingay? anyway, pa check mo yong bearing mo sa aircon or tentioner bearing baka yong ang maingay tapos bili ka bearing kay Sir Ungas, hehehe
    kay big berts kayo para sure ball! :D tried and tested.. sakin kayo magreklamo.hahaha
    Jan 2004
    sorry.. November 29 pala mga pre
    Jan 2004
    May shop ba si Sir Ungas?
    May 2004
    PM mo lang si Sir Ungas tungkol sa bearing alam na niya yon, sabihin mo sinabi ko, hehehe
    bulitas ang binebenta ni ungas.
    Apr 2004
    hindi na rin ako nagpapaengine-wash... detailing masmaganda pero hindi ko pa natry... minsan kasi pagmali yun engine wash, its either hindi malinis or may masisira...
    Jan 2004
    nung minsan nag pa engine wash ako sa shell (white plains), di naman ganito eh.. sinubukan ko lang dito sa petron stn sa may j.vargas kasi nga matrapik sa may white plains.. tapos ganito na ang nangyari.. huhuhu.. magkano ba pa-detail kay big berts?sandali lang ba yun? as in mahihintay? baka ipa-tune up ko n lang ito mamya.. given na madala ko sya pag di humagupit ang bagyong yoyong!
    Jan 2004
    or pwede ko bang sprayhan ng DW40 yung mga singit singit sa may bandang compressor and other joints/moving parts along that area?safe ba yun? sorry guys.. newbie sa auto.. di ko alam ang mga mekaniks eh.. thanks
    May 2004
    Subukan mo na lang pa tune up pre. Baka may nabasa dyan na hinde dapat mabasa o kaya may nalagyan ng tubig.
    Jan 2004
    yup.. okey sir.. thanks.
Engine Wash.. then nag-ingay ang makina
