Originally Posted by
izzy
Hi guys!
I need some advise. Yung 98 Corolla ko ayaw mag start. May redondo, pero walang spark sa hitension wires. This happened all of a sudden, without symptoms. Nag park lang ako, then nung aalis na ako, ayaw na. Everything was fine prior to this. Fuel pump was tested and found working fine.
Here's what had already been done:
1) First suspect was distributor. Dinala kay Rey Electrical, pinalitan ang pickup coil (wasak na, labas na yung mga strands), condenser (nag leak na), igniter (bumuka na) at rotor. Tested, working fine. Kinabit sa oto, wala pa din lumalbas sa wires.
2) ECU. Was brought to someone who knows how to check, buo daw.
Ano kaya next na dapat i-check? Any help will be appreciated. Thanks in advance!
