Results 1 to 16 of 16
    Mga Sir saan po kayo nagpapa tune up up ng diesel engine nyo and for how much also the scope of the job
    sir, pinaka-tune-up ng diesel kasi change oil ang valve clearance. (ang pagkaka-alam ko ha) , pero baka may mas maganda pang suggestion mga bro dito sa thread.
    Sep 2005
    sir,
    my opinion is kapag tune up sa diesel, air (clean or replace after 5th km) and fuel filters (drain water every 10th km. and replace around 30th km) lang.
    valve adjustments naman kapag nag ingay lang. kung di maingay, hayaan mo lang.
    usually ang replacement fuel filters ranges around +/-400 pesos and replacement air filter around +/-200 pesos.
    panong ingay?
    Aug 2005
    How about engine tune up for gasoline?
    Tune up ko covers the following:
    replace oil filter
    replace engine oil (mineral based) 6.5 liters
    Cost: Php1,500.00
    replace fuel filter (every 20k)
    replace air filter (every 50k)
    HTH
    for diesel: change oil
    oil filter
    air filter
    fuel filter (every 10k kms or every other change oil)
    for gasoline engine:
    spark plugs
    change oil
    change filters too
    visit our shop=)
    Aug 2005
    thanx gleen
    Kay Glenn or kay Ferdie. Di ko naman na pinapagalaw valve clearance. Baka lalo pang magkandaloko loko.
    Check owner's manual for required procedures.
    Apr 2004
    yung 2.5tdic pajero ko, 109Tkms na... dipa yata na check valve clearance.. kailangan na kaya?
    Sep 2005
    Quote Originally Posted by v22
    dieselNUBI, v22:
    kung maingay as in the engine is louder than the usual crackling sound, have the clearance checked. 109th mileage, pwede mo patignan. di naman magagalaw unless adjust nila. feeler guage ang gagamitin para malaman ang clearance. dont worry. di masisira iyan basta marunong ang gumagawa. mas fuel efficient ang properly adjusted valce clearance and di gaanong mausok.
    Sep 2005
    Quote Originally Posted by finchy18
    tama po si sir glenn
    spark plugs replace
    clean or replace air filter
    fuel around 30th km
    clean throttle body around 20th km (carb. efi=depending sa environment and sa pms mo)
    check timing (carb. efi =for those where the timing can be adjusted)
    valve adjustment depende rin sa vehicle. some have self adjusting. some are shim types which cannot be adjusted
    Apr 2004
    tnx banaweonline!
    Aug 2005
    Quote Originally Posted by banaweonline
    spark plugs replace
    fuel around 30th km
    thanx so much sir..
    about dis valve adujstment and clearance for my corolla carb sir simple tuned up lng ba and adujstments?
    Sep 2005
    thanx so much sir..
    what engine?
    what engine?
    Sir sa 2L diesel engine, how much you charge for valve clearance adjustment?medyo maingay na compare nong nabili ko.90T n mileage.
    And also,any qoutation sa replacement ng pressure plate,clutch disc,released and pilot bearing for 2L engine transmission, Toyota Hi-Ace commuter van.
    Saan po pala banda ang shop nyo...kung kaya ko qoutation nyo sa inyo ko papagawa.
    Thanks
Engine Tune UP
