Dod,
For a 2E engine, ignition timing varies on the fuel you use. I'd suggest 8 degrees BTDC if you're using unleaded 93+ octane fuel. 10 degrees btdc if you're using premium 95 octane fuel; and 11 or 12 degrees btdc if you're using 97 octane fuel.
Have your carb re-check the adjustments of idle mixture and idle speed screw. And be sure your valve clearance should be correct.
Hope this helps.
