Originally posted by yebo alam mo medyo complicated yan question mo. are you asking same car with different engine and tranny installed or completely different cars?
kung same car with different engine and tranny, then they MAY have the same top speed since the weight, coefficient of drag, frontal area, tyre size and type, etc etc etc are the same. it will finally rest on the final drive ratio from engine-tranny-differential. IF the final drive ratio are the same then the higher speed engine MIGHT deliver a higher top speed ON THE ASSUMPTION that the power delivered is enough to propel the car to that higher top speed. but most of the time the higher revving engine will be mated to a higher drive ratio tranny and differential so the top speeds will not differ much.
if you're comparing different cars then there are as many possible answers to your question as there are car models. you can't possibly compare apples and peaches.
ganun po ba? hehe... sorry! medyo curious kasi ako when it comes to cars lalo na with their engines... i also like comparing different kinds of vehicles with one another... kaya siguro napakcomplicated na ng question ko... hahahaha! im just just a kid you know? LOLS! pero kung sa bagay, there are pros and cons on different engines.. am i right? anyway, bout the 2 engines im comparing with... 2 different cars ang tinutukoy ko... ^_^
