Results 1 to 13 of 13
    How much kaya ang magpagawa ng engine support? And yung sensor, magkano rin kaya? May problema raw kasi mga sensor kaya di nawawala ilaw ng check engine ko.
    Jun 2005
    depende yan sa model ng sasakyan.
    yung sensor, depende naman sa kung anong sensor ng anong sasakyan
    1992 lancer po.
    Anong sensor po kaya yung para magstart yung kotse, minsan kasi hirap magstart. Hindi 1 click.
    Feb 2009
    Quote Originally Posted by Mits View Post
    1992 lancer po.
    Then your car's deficiency is the cranking system( battery, ignition switch, wiring, starter solenoid and/or stater motor). Somewhere along the chain is the cause of the intermittent no-crank/ no-start condition
    Mga magkano naman kaya ipagawa yan sir?
    Oct 2009
    may computer box naba ung lancer mo.
    pa scan nyo po para malaman kung anong sensor ang nagluluko sa kanya..at ma pinpoint po talaga ang sirang sensor.
    mahirap napo manghula ng sirang sensor.sayang lang pera nyo.
    Oct 2009
    Oct 2015
    Pa post, any idea where I can find near las pinas alabang prnque areaa, original front engine support for nissan 2007 GS 1.6L, puro replacement lng nakkita ko. thanks.
    Sep 2012
    Quote Originally Posted by -mi View Post
    Na try mo na magtanong sa Alabang Parts?
    Pwede din kasi magpa order dun na kukunin sa ibang branch nila in case wala sila hawak na stocks
    P2,276.00 sya sa Nissan Westgate. Baka mas mura sa labas.
    Oct 2015
    hi. just want to ask when I test the TPS sensor pg nka unplug ung connector, may 3v coming from the signal wire. pg pnlug ko nmn na ung tps and back-probe tpos connect the positive terminal to the signal and negative terminal to the ground, may "eeerr" sound. thanks sa mga mg rreply
    Oct 2015
    Quote Originally Posted by Macky View Post
    thank you. nka bili nko sa pasay. ung sa westgate na presyo 3.8k
Engine support and sensor
