Results 1 to 13 of 13
    Oct 2009
    Help sirs bakit ganon kapag naka off ang aircon ok naman ang hatak pero kapag naka on parang ang laki ng power loss na hirap humatak.
    Jun 2008
    ano ang car, gasoline or diesel engine.
    two things:
    a. have your compressor electrical load checked.
    b. have the compressor pulley checked, baka matigas na.
    Aug 2014
    yung na experienced ko dati, struggling when AC is on, kasi di nabalik yung vacuum hose na maliit from alternator to idle up nung ginalaw ito, pero not sure if sa bagong sasakyan which dependent on sensor, baka iba mechanism nung idle up.
    Aug 2013
    Quote Originally Posted by aioshin View Post
    kung low idling kapag nag engage compressor, isa sa posibleng dahilan ay sira idle up sensor.
    ano engine mo bro?
    Oct 2009
    Gasoline po sirs
    Oct 2009
    Wala naman kaya siya connection sa engine mismo? Kaya hirap humatak?
    Kung dati ok naman ang hatak kahit naka On ang AC possble hindi sa engine yan.
    Eto mga possible cause base sa experience ko sa mga naging sasakyan ko.
    1. Possible AC compressor bearing maganit na umikot, or yung compressor mismo. Kaya heavy load sa engine on Ac on. Take note iba pa ang compressor clutch bearing ha.
    2. Possible nag high pressure and A/c system. cause nito is clog system line (condenser, evaporator, hose line, etc) usually kapag naghigh pressure na ang system, hirap na and compressor kaya nahihirapan din ang engine.
    maganda pa check mo muna ang AC system mo, makikita ng isang reputable AC shop yan pag kinabitan nila gauge ang Ac system ng kotse mo.
    Dec 2015
    great site with great post.Chartered Accountant Firm in Lahore
    i think post plays a very good role in developing a forum much better..
    .I must say,a good attempt from your side.Chartered Accountant Firm in Karachi
    .i really appreciate your work..well done....keep doing good work..
    Apr 2010
    Quote Originally Posted by lanski770 View Post
    so yung compressor pala ang culprit ng rough idling ng makina while the aircon is on? yan kasi ang dilemma ko ngayon after repairing the aircon system ng tsikot ko (it's a 15 year old car, BTW). hindi ba kailangang ipaayos yung idling system ng makina even if the aircon is on?
    Aug 2014
    When you turn on the AC, it will need more electricity, so kailangan nya more power sa engine to compensate the alternator requirement. Yung dati ko sasakyan, sa service manual, merong idle up sensor, na hinde ko makita kita, pag turn on nung AC, bumabagsak RPM, pag off ng AC, nag nonormalized, and its a gasoline, pero wala sya nong katulad nung sa diesel na merong vacuum hose nakakabit sa alternator patungong idleup valve, na once turn on AC, ito yung mag cause nung rpm to rise when idle.
    Aug 2015
    Kung maingay pag ni on mo ang AC obserbahan mo ung compressor. Baka ung bearing nyan sa loob hindi na properly lubricated or nag leak na ang oil. Pag natuyo yan sira talaga. Kung luma na palitan mo nalang.
    lol i remember the same issue with my old nissan sentra
    parang gusto mong lagyan ng oxygen tank ang engine bay ng baka sakali makatulong sa engine sa pag hinga
Engine struggling when aircon on
