Results 1 to 11 of 11
    Apr 2008
    Sir, i need some advice/ idea regarding my problem my nissan sentra gx. last week while i was running slow (rush hour traffic) i was surpirsed that the engine suddenly shut down, no check engine light seen before it shut down. it just drops down dead. so i crank it 3x and it wont start, indicator lights on the dash board is same in normal starting, then after 20 seconds i tried to crank it and it did start and run normally. this same scenario happend to me 2 more times, one time i was running fast and it suddenly shuts down. any idea what is the problem? where to check? what to test? thanks in advance.
    Quote Originally Posted by danieyoyo View Post
    When was your last change oil sir? Spark plugs? Tune up? Check mo din fuel filter (every 20k ang palit).
    Start first with the basics:
    - Tune-up
    - Clean the MAF (Mass Air Flow) sensor with electric contact cleaner (this should be done every 10,000kms with the QG engines on the Sentra which are sensitive to dirt).
    - Clean the throttle body
    - Clean the PCV (Positive Crankcase Vent)
    - Check/replace fuel filter if this has not been done in the last 20,000kms.
    Apr 2008
    - Tune-up
    all done except with the MAF, PCV Cleaning and fuel filter replacement. ill give updates sir. many thanks
    Jan 2011
    have you check the fuel pump? correct me if im wrong but i think electronic na ang fuel pump ng car mo. it could be. pa wala wala na ang signal ng pump. hope this helps.
    Apr 2008
    Quote Originally Posted by shelu View Post
    yes sir, but the thing is pag tumirik na ang engine. ill just have to turn the ignition key off then after a few seconds (10-20 seconds) pagstart ko nagstart naman ng normal, meaning gumagana ang pump. thanks sir
    Jan 2011
    you might be wrong sir. it could be shortage of fuel supply due to faulty fuel pump. gumagana ang pump kaso, kinakapos ang supply. kung may mahiraman kang electronic fuel pump sa suki mong shop, subukan mo muna trial and error. baka ito nga. it happen to me before, same scenario. hope this helps.
    ^another sign of a dying fuel pump is the pre-start (engine key "on") hissing sound common on some Nissans (not sure about the N16) is absent or faint before you start the engine.
    Nov 2011
    ^ if it starts again after a short break it could be a overheating distributor if equipped...
    Apr 2008
    Quote Originally Posted by jresperanza View Post
    im thinking of the fuel pump relay, but i cant find where it is..
    Apr 2008
    update, from monday so far hindi pa ulit tumirik. what i did is, clean the spark plugs, check the relays and fuses, i checked the fuel pump and filter malinis naman sya pati ang fuel. i also change the fuel pump fuse. hope d na sya umulit, nakakatakot pag nakarekta at baka biglang tumirik.. delikado... update ko ulit kayo mga sir. thanks
'05 Nissan Sentra Engine Occasionaly Stall
