Results 1 to 10 of 19
June 11th, 2006 09:38 PM #1
I have posted this in the diesel section, maybe I have place it in a wrong thread..kaya walang reply, ill repost it here again..
Bought a 1985 S10 chevy pick-up with original V6 engine replace it with a B2200 mazda turbo diesel engine, however it experience hi pressure on the diesel engine. we have add another auxuliary fan ganun pa din, we re place the auxilary fan sa ilalim still nag iinit pa din. the problem is pag nag over heat biglang numihinto makina. I have replace the radiator with a new 1 one, ganun pa din..I need advice. Im planning to sell the pick up less the engine. do u think the b2200 is not match with the pick-up. help! any referal from a good mekaniko?
Thanks
June 12th, 2006 09:08 AM #2
things to look for:
1. is your water spilling over to the reservoir?
2. does the water from your radiator empties into the resevoir.
3. do you see bubbles or foam forming in the radiator when you rev the engine without the radiator cap?
if all 3 above are present check your cylinderhead gasket. could have a leak between the water jacket and the chamber.
also check your themostat. it could be stuck.
good thing your engine dies when it overheats...or else your con rod bearings would seize.
June 12th, 2006 09:12 AM #3
related sa post niyo afrasay, i filled up the coolant container ng paj namin to the full mark about 2 months ago or so. now it's almost at the bottom indicator, and i see a lot of dried up coolant near the top of the bottle sa labas...related na yan sa issue right?
June 12th, 2006 09:47 AM #4
may times na when you look at the resevoir nasa low side siya ng marker sometimes nasa full coz water get siphon and return to it due to the pressure built-up sa radiator pag mainit and the pressurize cap opens it releases water to the resevoir and siphons it when it cools down. as long as there are no leaks ok ang cooling system mo.
June 12th, 2006 09:48 AM #5
o baka naman nasobrahan ng rough roads yun pajero mo at nag spill na yun water ;)
June 12th, 2006 09:51 AM #6Originally Posted by afrasay
June 12th, 2006 10:37 AM #7things to look for:
Thanks po
Tsikot Member Rank 5
- Nov 2003
- 3,849
June 12th, 2006 10:52 PM #8never use the car till the engine stops. ang sama nyan meaning di na nya kaya.
Toyota is my choice
- Aug 2005
- 2,063
Suzuki JIMNY [merged threads]
