Results 1 to 5 of 5
- 8
March 13th, 2007 10:57 PM #1Guys help naman, My ride is 97 ssangyong musso A/T gas. Lately, bigla na lang parang nagbobog down yung engine nya slowly until it completely stops? Pero pag ni re start ko naman ok na ulit. parang nirereset lang tapos good to go na ulit? bakit kaya ganon? Although it happens only once in a while and when it happens i usually look at the instrument panels and no signs of "check engine" or "check transmission" is evident? Otherwise, suggest naman kayo ng shop na pede kong pagcheck up an, kasi from what i've learned, e mercedes ang engine and transmission nito kaya di ko naman maipacheck basta basta. Laguna nga pala location ko. Any shops in Metro Manila is ok. Any help from you guys will appreciated.
March 14th, 2007 01:35 AM #2
Dirty Throttle Body?
Kapapalinis ko lang ng sakin. Sinabay ko na rin ang oil change.
Look: http://forum.fordclubph.com/viewtopic.php?p=21734#21734
Yung sa akin, after ng start-up biglang mamatay. Kung irerev or bukas air-con tataas ang idling hindi mamamatay pero pagka-bitaw biglang zero ang rpm. Ang masnakakatokot, habang tumatakbo biglang mamatay ang engine! Walang problema sa iginition bukas agad makina.
Link: Click to watch video: Engine dies after ignition
Most probably ang problem ng sayo "DIRTY THROTTLE BODY." Madali lang yan. Use throttle body cleaner, spray mo sa TB then punasan/brush mo ung carbon build-up. Naninikit kasi ung dumi kaya nahihirapan magbukas sara ang TB.
Link: How to clean Throttle Body
mahal ang MAF Sensor. yan na lang muna.
Hope that helps.
- 8
- Feb 2005
- 342
March 18th, 2007 12:36 AM #5If throttle and filter are ok, maybe you need to check the gas tank. A bit old school but sometimes there are a-hole gas fillers that put paper or other things in your tank. If the filter is really dirty you might want to have your tank checked in case there are impurities that came from the gas stations.
It may also be helpful if you can think back to what you did to the car just before and up to a week before the problem first started. Was there any work done on the engine? When was your last tune-up?
