Originally Posted by
bambino
sa O2 sensor makikita kung bakit rich yan .
sample scenarios are ;
if the O2 sensor is lazy and stuck at low,the result will be rich ,why ? it's because the ECM was seeing it as a very lean condition.
coolant sensor ,if it stucked at cold ( 4-5 v reading is considered cold) the computer will give more fuel .
or if the vacuum is low the map sensor will make it rich too (if equipped)
alot of things to be checked first before attempting to change any major parts suspected.
the best thing to do is you to find a shop who is specialized in ENGINE DIAGNOSTICS not the shops who can only change parts and get lucky .
otherwise you're at risk of getting the same results and that will be a problem.
