Results 1 to 10 of 16
- Oct 2008
- 8
May 29th, 2009 06:34 AM #1im driving a Nissan cefiro a32 97 model.
idling prob. fluctuating sobra. lalo pag cold start. then namamatayan ako pag mabagal ako or biglang shift to D or pataas na mabagal.
nalinis ko na anf throttle body and napaayos ko na ang air leaks. whats else could be the prob?? please help. TIA
May 29th, 2009 06:49 AM #2
ECU reset, fuel filter/pump/relay. I'm talking not only for Nissan Cefiro specific here.
- Jan 2005
- 1
May 29th, 2009 07:25 AM #3Try spraying the MAF sensor with CRC contact cleaner. Be very careful with this MAF sensor as this is very delicate. Just spray the wire part, but do not touch it. My Nissan Exalta'02 had the same problem, and I was able to cure this by just cleaning this sensor. You can buy the CRC contact cleaner in Tru-Value or Robinson Handyman.
THE AUTO SPECIALIST
- Mar 2006
- 607
May 29th, 2009 12:29 PM #5
hindi ako familiar sa behavior ng mga makinang may ecu, kung traditional na engine yan... i'd say check your fuel filter, fuel lines and fuel pump.
- Oct 2008
- 8
May 29th, 2009 10:38 PM #6i had it checked na by the comp.. busted knock sensor. i replaced it na dn. cleaned the MAF also.. ganun pa dn... im running out of options here.. help bro....
June 11th, 2009 06:02 PM #7
- Jul 2008
- 3
October 4th, 2016 03:48 PM #9
- Apr 2016
- 130
October 4th, 2016 08:36 PM #10try the basic tune up process also, spark plugs tension wires, coils etc. i might be wrong but it never hurts to try
VinFast VF 3
