Results 1 to 6 of 6
April 12th, 2007 08:30 AM #1
Mga fellow tsikoteers, tanong lang po. Will it be beneficial, fuel consumption and acceleration-wise, to:
1. Replace my OEM air filter with K&N or any other similar brands? Am I going to replace only the filter element (drop-in) or do I have to remove the whole OEM filter assembly and install an "open-type" K&N racing filter which I usually see on other mod-up cars? Pasensya na po, I'm not familiar with this.
2. I've read somewhere about Turbo timer. Does it really help to have one?
Maraming salamat po.
April 12th, 2007 10:33 AM #2
turbo timers are more of a safety feature to preserve the turbo's life. it lets the oil cool down before shutting down the engine. it's also for convenience.
April 13th, 2007 10:18 AM #4
Using K&N drop in filter will give you more power and economy for your ride...
WBR,
April 14th, 2007 06:39 AM #5
Many thanks, Innova Boy. I'll replace my OEM filter with K&N as soon as I get back in the country.
April 14th, 2007 03:30 PM #6
sure and pls give us some feedback after you have change it if my recommendation is correct....
WBR,
As long as it is valid, bring a printed copy. Then, they will ask you to use one of the PCs there...
