Results 1 to 4 of 4
    Nov 2006
    Mga sir,
    Good am. Pahelp naman. I have a Ford Lynx GSI 2001 Model(1.3 Engine). Recently pinaayos ko yung starter nung sasakyan. Naayos naman pero right after that, kaso nung tinakbo ko na. kumakadyot at sobra yung nginig while idle, found out na nabunot yung connection ng sparkplug. So ginawa ko ay nireset ko yung battery. May konting nginig pa din. Dinala ko sa pagawaan at sabi sa akin, need daw dalin sa Casa para daw ma diagnose, help naman, baka may suggestion pa kayo na pede ko gawin. Thanks.
    Aug 2010
    Just. Have. it. diagnosed.
    It's like asking what prescription drugs to buy without even knowing what you're suffering from.
    Quote Originally Posted by carlo_41786 View Post
    Mga sir,
    i would check all the hi tension cable connections and the cables themselves. baka maluwag at nag-mi-misfire..
    also the sparking plugs at baka madumi, kaka-iba ang spark gap, o dapat nang palitan..
    i would also have timing checked..
    all these, puedeng gawin ng matinong mekaniko.
    kung ayaw pang tumino, then i would go for the more-expensive electronic thingamajigs..
    Apr 2011
    hello po:-)
    ano po ang sign ng defective or bad turbo.
    many tnx:-)
Engine "Shaking" while on idle
