Results 1 to 10 of 12
- Apr 2017
- 35
December 16th, 2017 02:43 PM #1Magandang araw po mga masters, hihingi po sana ako ng suggestion/advise niyo kung saang shop sa Las Pinas or Alabang ang ma rerecomend ninyo sakin regarding sa engine oil leak ng toyota innova 2008 ko. Hindi ko ekasktong alam kung saan nagmumula ung leak, hindi namn ganoon kalakas ung tagas pero may makkita sa block at may mga kaunting tulo na makkita sa sahig sa garahe. Bought the car last march running at 80,000 kms na sya, first time ko lng dn mag ka sasakyan kaya nag.aalala ako kung ano ung leak then isasabay ko na dn sana ung tune up (anu ano po ba ang dapat palitan base sa mileage nya na 80k kms?) magkano rin po kaya ang aabutin ng budget sa estimate? Maraming salamat po sa tulong niyo.
December 16th, 2017 02:59 PM #2
dapat di nagkaleak yan, tampered siguro ang odometer. diesel or gas?
- 52,697
December 16th, 2017 03:31 PM #3there are many causes of leak, and the cost of repair will depend on what the cause is. it could be a perished sump drain gasket, a distorted sump, a perished crankshaft oil seal, a perished or loose head gasket, even as simple as a loose oil drain plug!
most estimates are free, as they are based only on what is visible. but you should be ready for the worst, which might become evident only after the mechanic actually tinkers with the engine.
i am sorry that i can not give you an estimate.Last edited by dr. d; December 16th, 2017 at 03:42 PM.
- Apr 2017
- 35
December 16th, 2017 07:40 PM #4
- Apr 2017
- 35
December 16th, 2017 07:44 PM #5
- 52,697
December 16th, 2017 07:53 PM #6
December 17th, 2017 12:07 PM #7
Yung dalawang shop na magkatapat sa Alabang Zapote Road ...
1) Servitek
2) Prens Auto Supply and shop
Na try ko na pareho yan maayos naman sila kausap
Sent from my ASUS ZenFone 4 using Tapatalk
December 17th, 2017 05:35 PM #8
- Oct 2009
- 2,271
December 17th, 2017 06:08 PM #9kadalasan ung valve cover gasket lang.kung simula sa itaas pababa.or kung may tagas din sa bandang harapan.malamang crank oilseal .
pero pinaka maganda dyan ipa engine wash mo sa gasoline station para malinis mabuti ung makina tapos saka mo obserbahan kung saan may kakatas na langis para madaling ma trace ung pinang gagalingan.
December 17th, 2017 06:12 PM #10
leak could be caused by the pcv failure. there is higher pressure in the engine hence some leak...
google: oil leak due to pcv valve
Suzuki JIMNY [merged threads]
