Results 1 to 12 of 12
    Apr 2017
    Magandang araw po mga masters, hihingi po sana ako ng suggestion/advise niyo kung saang shop sa Las Pinas or Alabang ang ma rerecomend ninyo sakin regarding sa engine oil leak ng toyota innova 2008 ko. Hindi ko ekasktong alam kung saan nagmumula ung leak, hindi namn ganoon kalakas ung tagas pero may makkita sa block at may mga kaunting tulo na makkita sa sahig sa garahe. Bought the car last march running at 80,000 kms na sya, first time ko lng dn mag ka sasakyan kaya nag.aalala ako kung ano ung leak then isasabay ko na dn sana ung tune up (anu ano po ba ang dapat palitan base sa mileage nya na 80k kms?) magkano rin po kaya ang aabutin ng budget sa estimate? Maraming salamat po sa tulong niyo.
    dapat di nagkaleak yan, tampered siguro ang odometer. diesel or gas?
    Quote Originally Posted by kaloi01 View Post
    there are many causes of leak, and the cost of repair will depend on what the cause is. it could be a perished sump drain gasket, a distorted sump, a perished crankshaft oil seal, a perished or loose head gasket, even as simple as a loose oil drain plug!
    most estimates are free, as they are based only on what is visible. but you should be ready for the worst, which might become evident only after the mechanic actually tinkers with the engine.
    i am sorry that i can not give you an estimate.
    Apr 2017
    gas po, any recomended chief na shop?
    Apr 2017
    i hope na hindi naman masama ung tama, thank you for the input sir appreciate it. Any shop you can recommend sa alabang or lp? thank you sir.
    sorry, but sa banawe in QC ako nagpapagawa...
    Sep 2012
    Yung dalawang shop na magkatapat sa Alabang Zapote Road ...
    1) Servitek
    2) Prens Auto Supply and shop
    Na try ko na pareho yan maayos naman sila kausap
    Sent from my ASUS ZenFone 4 using Tapatalk
    Customer's cradle sa harap ng perps
    when you look into the abyss, the abyss looks into you
    Oct 2009
    kadalasan ung valve cover gasket lang.kung simula sa itaas pababa.or kung may tagas din sa bandang harapan.malamang crank oilseal .
    pero pinaka maganda dyan ipa engine wash mo sa gasoline station para malinis mabuti ung makina tapos saka mo obserbahan kung saan may kakatas na langis para madaling ma trace ung pinang gagalingan.
    leak could be caused by the pcv failure. there is higher pressure in the engine hence some leak...
    google: oil leak due to pcv valve
    Jun 2008
    Palit pcv then engine wash para makita saan galing ang leak.
    Sent from my NX549J using Tsikot Forums mobile app
    Apr 2017
    mga master salamat po sa mga suggestion at payo ninyo. as january ko na sguro ito ipapa check malapit na kasi ang holiday season kakailanganin namin sa bahay ung sskyan, a update ko po kayo ulit kung anong mgyyare.
    PS: Anyone na nakapag pagawa na sa martin's car accessories sa may atc? duon po kasi ini rerefer si tatay ng mga kakilala nya. pa feedback na rin po sana ( psensya na mga idol antanong ko natatakot lng kasi ako ma victimize nung mga casa horror stories chaka ung mga manloloko sa talyer ) salamat.
engine oil leak
