Page 1 of 3 123 LastLast
Results 1 to 20 of 45
    I have a an almost 15000kms pajero, it's casa maintained and they say na every 10k ung change oil ko, I use fully synt oil, gusto ko sana every 5k ang change kasi city and provincial use ito and with all the traffic dito sa city natin. With my gas powered ride, I change every 10k, fully synt oil din gamit ko. What's your usual interval guys? OK lang ba sa diesel ang every 10K. Thanks.
    10 for my ride is too much...
    5thou dapat sa diesel ride ko..
    pero diko na pinapaabot..
    3,500 or 4thou palang..palit oil na....
    every 3000KM
    ako po sa 14 year old Pajero ko, 5000kms, semi synthetic oil. :roll:
    5k sa mineral oil
    10k sa synthetic oil
    Jan 1970
    every 5,000 kms semi synthetic oil
    welcome to tsikot and dieselclub tuesday!
    so bukas dapat ang handle mo wednesday he..he
    Quote Originally Posted by kimpOy
    :lol:
    ako 5,000km diesel. sa gasoline synthetic every 10,000km
    So 5k ang most preferred interval ninyo. And I read somewhere na Metro Manila driving is considered harsh driving conditions. I'll do mine every 5k na lang para maalagaan ang investment ko. Am currently using OWS fully synt oil, have you guys tried ung Mitsu fully synt oil for diesel? Any feedback
    every 5k din ako.
    every tuesday lang sya pwde mag post :wink:
    Signature
    5K din for me and I use mineral-based oils.
    Sabay palit na din ng air filter every 5K (generic only).
    Jan 1970
    Actually, depende sa brand/make ng ride. Suzuki, for instance, every 5000 kms. Honda Civic naman mga 10000 kms. Anyways, in general, important ang 1000, 5000 and 10000 check ups.
    salamat po =) madali lang ba magpapalit palit ng handle? or dapat every tuesdays lang ako mag login dito? :roll: :lol:
    yung every 3000km is on Delo500 SAE40W.... on change oil palit ang oil filter... and every 2 months.. palit ang primary fuel filter, and every 6 months palit ang secondary.
    Apr 2003
    Mga peeps,
    Ano ang magandang semi-synthetic engine oil? Tnx
    Jan 1970
    yung advice ni jackaroo sa akin... Mobil Delvac 15W40.... he.he... meron ba semi-synthetic ang Delvac
    oil interval at 4000Km
    usually 3000km or 3500km ang change oil ko kasi, nauuna ang 3 months na due bago maka 5000km
    Dec 2002
    wombat,
    Who makes OWS synth oil? What's the viscosity/ API/ Acea rating? Is it made for diesel or gas engines?
    A good full synth diesel oil can handle 10k km drain intervals BUT you have to replace the oil filter(OEM or quality replacement) every 5k km(then top-up) and air filter also every 10k km. The oil/air filter removes dirt from the synth oil which doesn't break down easily.
    Can't compare the protection from a mineral oil vs a synth so even 3k km intervals on a mineral oil will have higher wear than a full synth at 10k km.
    Don't recommend semi-synth oils, their base oil is mineral with synth additives which means the oil will still deteriorate.
    D4BB engine was every 10K with Mobil Delvac used then refill with another fully synth brand oil during 5K when changing filters.
    TD42 engine every 5K using Petron All Terrain full synth.
    Dec 2002
    Ungas,
    How does this oil perform in your TD42? What difference did you notice?
    ako din every 5 thou km when i was using delo multi, but il try the my fully synth na 0W-50 by polo lubricants, bka pwede 10 thou with oil filter change in betweeen. pucha kasi tong safari 10 liters of oil. glenn would agree, ang gastos!
What's your change oil interval for diesel rides?
