Results 1 to 6 of 6
October 23rd, 2006 03:49 AM #1
i have a hatchback and pinapalitan ko engine nito! simula nung pinalitan yung engine madalas na umiilaw yung check engine sign sabi sakin okie lang daw yun kasi palit na daw yung engine! so okie lang ba na umilaw ang check engine sign pag palit na engine ng sasakyan?
October 23rd, 2006 07:34 AM #2
hindi. niloloko ka ng nagsabi nyan.
there's a reason why your CEL's lighting up. you can diagnose this yourself if you can tap into the CEL wire of your ECU. search mo lang sa net yung ECU codes.
or you can bring it to a shop and have them diagnose it for you.
i had a hatch before and nag change engine na ko. CEL didn't light up unless there was a a problem.
October 23rd, 2006 08:30 AM #3
Ayus ahh.. sarap batukan nun nag sabi sayo nun!
ilang beses nako nag papalit ng engine sa vti ko never pa nag check engine! cguro may mali sa harness nung oto mo!
Punta ka sa ibang mechanic at ipa diagnose mo sa kanila kung anu problema, madali lang yun!
Bro suggestion ko lumipat ka na ng mechanic!
October 23rd, 2006 08:53 AM #5
magaling naman yung mekaniko nya kayo naman. nakapag-engine swap nga yung mekaniko eh (sya nga ba?)..... yung nga lang mali yung sinasabi nya
baka naman di sya marunong magkabit nung harness or wiring nung check engine indicator. baka naikabit nya sa kung saan-saan hehehe
October 23rd, 2006 11:14 AM #6
sabagay pa check ko na nga din siguro!!! baka may mali sa wiring or something! thanx guys
Xiaomi E-Car
