Results 21 to 30 of 43
- Nov 2002
- 162
January 16th, 2003 01:49 PM #21patanong din,
I've noticed on some cars, may parang heat shield yung sa headers nya, (I'll try to get pix) so nahihiwalay yung header from the radiator kumbaga.
Kung gusto ko gayahin to should I:
a) use something that absorbs the heat, metallic
b) use something that blocks the heat, fiberglass or other insulating material
Iniisip ko B dapat kasi ganyan yung purpose ng header wraps, pero why are the stock heat shields metallic, or meron lang insulating material sa ilalim nun?
magulo ba? :oops: haha
- Nov 2002
- 65
January 16th, 2003 04:09 PM #23Originally Posted by boybitz
Stock headers sometimes have a sheet of metal over them being used as a heat shield and its effective. Reason is its reflecting back the heat that is being radiated from the headers. You can check the way its installed, there is a small gap between the headers and the heatshield. The heatshield does get hot though.
Having header wraps is more effective. But its a time consuming task to wrap every headers that comes down the assembly line. The heatshield is a simple device that can be bolted on in a few seconds.
January 16th, 2003 08:13 PM #24Originally Posted by ghosthunter
January 16th, 2003 08:15 PM #25Originally Posted by ghosthunter
January 17th, 2003 02:08 AM #26Originally Posted by ssaloon
January 17th, 2003 02:14 AM #27
so when i have my headers fabricated, i'd just tell them to make them with longer pipes?
also, where would you recommend to have headers installed?
i saw a thread in another msg board saying that he could refer me to someone who fabricates pipings using mandrel bent pipes. siguradong mahal yun! :?
January 17th, 2003 02:20 AM #28Originally Posted by ssaloon
January 17th, 2003 02:26 AM #29
pwede na ipafabricate from headers all the way to exhaust pipings with mandrel bent pipes right? tapos kabit nalang sa muffler ko? tama po ba?
- 237
January 17th, 2003 08:45 AM #30prof ghosthunter:mrgreen:
prof, somebody kasi told me na replacing the exhaust pipe can help improve engines performance (pero un nga limited kasi 1.3 carb siya), btw he is also using a 1.3 carb lancer.....tapos di naman daw maingay...
another alternative, can putting cold air into my intake help increase hp or faster accelration?lets say un lang ang mod na gagawin ko sa engine ko.....kasi pansin ko, the carb performs well pag malamig surroundings (like kung umuulang or kung gabi na)
i think there's a way na malagayan ng conetype ung mga carb diba?lalagyan lang ng tube?kasi ive seen this lancer gl, carb na 1.5, naka conetype tapos may tube...
high idle RPM at engine start
