Results 1 to 10 of 10
- Sep 2007
- 110
November 3rd, 2007 08:49 AM #1gud day fellow tsikoters.. may leak sa may ilalim ng engine ko. pinatingnan ko sa shop sabi nila oil seal daw kailngan dun. kailangan daw i down ang tranny para malagyan ng oil seal. my car pala is '97 honda civic ek a/t. natatakot kasi ako baka pag na down nila ang tranny may magalaw na sensor at lalong lumaki problema. Tanong ko lang guys kung safe ba na ibaba ang tranny? wala bang possibility na magagalaw nila mga sensor ng a/t tranny? talagang takot akong ipagalaw. iniisip ko since konti lang naman ang tagas buti pa di na lang muna ipagawa. i'm using a thicker oil na lang right now para di masyadong lumakas ang leak. help me guys.. thanks
November 3rd, 2007 09:33 AM #2
kung oil seal yan, sa may distributor lang yan.. d na kelangan ibaba ang tranny.. mostly sa may part ng vtec solenoid minsan and leak nyan or yung oil seal mismo. walang kinalaman ang tranny unless may tama na ang tranny mismo.. try mi muna check ng mabuti..
Tsikot Member Rank 4
- Jun 2006
- 2,605
November 3rd, 2007 12:30 PM #4
There is a front and the main oil seal. Replacing the main will require you to bring down the trans. When was the last time you replaced your clutch disc, p.plate and release bearing? kung di pa malakas ang tagas wait until your clutch is sliding to replace it para isang trabaho.
November 4th, 2007 03:44 AM #5
The question is saan galing ang leak?
Kung leak ang paguusapan madali mo lang hanapin kung saan nanggagaling ang leak nayan. Maraming bagay ang panggalingan, maaaring galing sa Valve cover gasket, sa distributor oil seal, cylinder head, oil pan gasket, oil drain plug baka busted, transmision pan gasket or maybe loosed bolt at kunting higpit lang mawawala na(unless sira gasket). Trace kung saan galing ang leak na yan then decide kung anong gagawin mo.
- Sep 2007
- 110
November 4th, 2007 07:32 AM #6
sir yung oil is coming from in between the a/t and the engine. sabi ng mechanic sa crankshaft daw yata if im not mistaken. kailangan daw i down ang tranny kasi di raw kayang dukutin yun. when they checked it, engine oil daw talaga ang tumatagas. according to them, it will only need oil seal to stop the leak. ganun daw talaga pag nagiging luma na ang car nagkakaroon ng leak. binasa ko yung "the engine bible" may part dun ng engine and i think the rear bearing seal ang may leak sa akin. kasi ang opposite nya is front bearing seal dun malapit sa timing belt diba? andg concern ko lang talaga is baka magalaw ang mga sensors pag down ng tranny. wala po bang maapektuhan na mga sensors pag down ng tranny? di pa po ako nag palit ng clutch or anything sa tranny ko.
- Sep 2007
- 110
November 4th, 2007 06:16 PM #8
November 4th, 2007 06:48 PM #9
it is possible na crankcase seal nga yan. anyways no need to worry about your clutch. wala ka nun. hehehe. A/T ang sasakyan mo right? you might as well download a service manual para sa model ng car mo. para alam mo rin kung paano ang assembly. actually, it really helps kung alam mo ang internal workings ng kotse, kahit di mo sya alam ayusin.
Tsikot Member Rank 5
- Nov 2003
- 3,849
November 5th, 2007 08:23 AM #10if marunong naman yung gagawa then pulling down the tranny should be easy work.
as above, if you want to go OEM-style, get a "spare tyre lock". but i use an ordinary cheap...
