Results 1 to 19 of 19
    Hello, I need advised sa engine ko, this morning I went to top hill it's about 12 kms deretso, when reach sa taas, masyadong mataas ang engine temp more than 3/4 ng temp gauge, but regular driving sa city or high way d temp ay below half lang siya, need advised on my engine cooling system. thanks
    Nov 2006
    medyo kulang ang information na binigay mo para sa concern mo,but anyway may i ask you this,ano kotse mo? gas or diesel? did you check the coolant level? if not,.check mo muna coolant level,if ok,,then the problem of yopur concerned is either thermostat or temp sensor,,pls have somebody to check that.
    I have surplus nissan terrano TD27T engine deisel, coolant level is okay, new thermostat, saan makikita yong temp sensor? city driving even traffic w/ aircon no problem, just this morning I went to hill top then I noticed the temp is going high, but the water is not boiling, mataas lang ang temp niya. thanks
    Jul 2006
    How steep is the hill?
    Sounds normal if you had a full load and were going up the hilll with AC too.
    Yes w/ aircon, 5 person, I can compare like canon road in Baguio.
    Jul 2006
    Then it's normal. You have a full load with 5 people and with AC. Engine is pushing the car up the incline with a full load and with the extra load of AC so it has to work more.
    Hi there...I've a problem with my car...it's a 1994 nissan altima...mataas kasi un menor when i start the engine then medyo nababawasan when i turn on the a/c...the first mechanic that i consulted told me i had to change the cylinder head kasi daw may singaw na un makina...but when i consulted the mechanic from shell...sabi nya pwede pa daw un cylinder head...ano ba talaga?
    Nov 2006
    Quote Originally Posted by kwiksilber View Post
    try to have your idle up controller checked...based on the observation that when you turn on the AC, the rpm goes down.
    yup. maybe idle up problem yan. ganyan din nangyari sa mazda ko.
    [SIZE=3]Hi there...I've a problem with my car...it's a 1994 nissan altima...mataas kasi un menor when i start the engine then medyo nababawasan when i turn on the a/c...the first mechanic that i consulted told me i had to change the cylinder head kasi daw may singaw na un makina...but when i consulted the mechanic from shell...sabi nya pwede pa daw un cylinder head...ano ba talaga?[/SIZE]
    Jan 2004
    kwiksilber, double post ka. paki-delete na lang yung isa mong post.
    thanks.
    Mukang na double nga?
    yup na experience ko rin yan i was driving a kia carnival pataas paunta baguio pero nun nasa taas na kami bumalik din sa normal range yun gauge nya
    I hope normal lang, bukas schedule akong land trip Cebu to Manila, medyo maraming akyatan din and dadaanan ko, thanks
engine getting high temp during uphill
