Results 1 to 10 of 11
- Dec 2009
- 7
December 30th, 2009 07:08 PM #1good day mga sir,
i have a problem w/ my '00 lancer mx... my mechanic said may problem daw sa 3 injector nozzles. so nag-canvass ako and to my surprise.. each nozzle cost about 6k each!!!
mga sir i desperately need cost effective suggestions... help help help!
many thanks and HAPPY NEW YEAR!
December 30th, 2009 07:21 PM #2
- Sep 2006
- 1,335
December 31st, 2009 12:28 AM #3
- Dec 2009
- 7
December 31st, 2009 04:38 AM #4
December 31st, 2009 11:52 PM #5
- Dec 2009
- 7
January 1st, 2010 12:50 AM #6
January 1st, 2010 05:26 AM #7
January 1st, 2010 12:03 PM #8
what test kaya ang ginawa ng mechanic mo to reach that conclusion? tinanggal ba niya ang fuel rail with the injectors attached and nacheck nya actually kung barado nga ang injectors? try mo pm si 4jgtootsie nag rerecondition yata sila ng injectors.
THE AUTO SPECIALIST
- Mar 2006
- 607
January 1st, 2010 02:49 PM #10
1chock3,
with all the maybe's, maybe the connectors to the injector have corrosion. thought it is possible they are indeed clogged, but three not working satisfactorily? you can confirm by measuring current to the injectors through connector B40 at the pcm. the wires to the injector are yellow-light blue, yellow-black, llight blue-green and light green-white
jick
***y welds! Apparently the subcon that makes the part replaced a worn welding tip but did not...
Chery returns to PH
