Page 1 of 2 12 LastLast
Results 1 to 10 of 12
    Aug 2010
    i just replaced my clutch assembly (disk/plate/release bearing) and done regular change oil last weekend but eventually i got engine check error P0113 and P0135 which indicates air temperature sensor voltage is too high and error on heater sensor. I tried to reset the engine check error by removing the terminals of the battery then drained it for 20minutes. But I still get engine check error indicator. My engine become and warmer than the usual. help pls!
    Thanks and cheers!
    villhen
    Jan 2011
    more info sir, car model, year mod, EFI or Carb type?
    Aug 2010
    honda city idsi 2004 manual
    Jun 2006
    most likely fix is change sensors
    Jan 2011
    Quote Originally Posted by userfriendly View Post
    but what if the sensors are working properly? they are there for obvious reasons. take it to a reputable shop. something is really wrong with your car.
    baka nagooverheat ka. i dont think its the sensors.
    have it checked and scanned.
    Feb 2009
    recheck and confirm the connections both on the HO2S and the IAT. there is a big chance the "mechanic" failed to reconnect them.
    Aug 2010
    familiar ka ba sir kung san yung mismo nakapwesto yung sensor na to?
    Eto yung lumabas sakin:
    P0113 - Intake Air Temperature Circuit High Input
    P0135 - Oxygen O2 Sensor Heater Circuit Malfunction (Bank 1, Sensor 1)
    Thanks!
    Feb 2009
    Quote Originally Posted by athlon64 View Post
    Thanks!
    your IAT is located along the intake air duct it will have two wires RED-YEL and GRN-YEL
    your HO2S wiring is behind the radiator on the exhaust manifold just upstream from the catalytic converter, it will have four wires WHT, RED, LT GRN, and RED YEL
    Aug 2010
    P0113 error has been resolved. I did some cleaning on sensor located near intake and MAP sensor located after throttle unit. I used throttle cleaner and contact point cleaner. After OBD2 reading, P0113 disappear.
    Next thing will do now is to check HO2S wiring...
Engine Check Error - Extreme Hot Engine
