Results 1 to 8 of 8
    May 2008
    Kamusta? I have a Honda Accord 96 that has a problematic engine block. I was supposed to get one of the engine supports replaced but what the mechanics discovered is that wala na masasalpakan ng turnilyo doon sa block kasi maluwag na yung mga thread tapos parang namumuti. They made a ridiculous claim that I have to get the whole engine itself replaced or just the block. Maghanda daw ako ng mga 75k. Walang hiya. I asked for second and third opinions, ima-machine shop lang daw yung kabitan ng turnilyo kaso wala idea yung mga pinagtanungan ko kung magkano magpa-machine shop ng engine block.
    Gusto ko lang magkaroon ng idea kung magkano magagastos magpa-machine shop ng engine block.
    Salamat.
    drill and tap to next bigger size bolt lang ang solution dyan. say if the original bolt size is 10 mm then drill it to the hole size for a 11 or 12 mm bolt then rethread it using a 11 or 12 mm tap. so ang steps na gagawin mo is...
    1. find out what size is the original bolt. japan yan so metrict size yan.
    2. check if the metal around the bolt hole is still thick enough.
    3. buy the next bigger size tap. look at the side of the tap, the drill bit size is written/stamped on the tap stem.
    4. buy that drill bit size.
    5. syempre bili ka din ng bolts na ganun ang size.
    then DIY na lang yan
    May 2007
    Tama ang sabi ni YEBO, drill and tap to next bigger size lan yan and save you thousand of pesos. Kung may kakilala kang nagtratrabajo sa machine shop siya nalang ang kausapin mo, baka isang case lang na COLD BEER ang katapat niyan. Yong mekaniko, FIRED OUT mo nayan at kayo nalang ang mag-install, even a kid could do the job.
    Oct 2007
    yup mas madali ang mag over size, kung walang problema para sa mga katabi, pero kung machine shop naman mag papa re build ng damage part mura lang din naman yan, find a good reputation machine shop para maganda ang trabaho...yon nga lang posible na mabaklas ang engine block para ipa machine shop...try drill muna..
    +1... no need for machine shops yan.... hand tap lang and drill panalo na yan.
    yung akin din, sa valve cover ko naiwan yung tornilo sa loob, walang head na makita kaya kailangan na drill...
    sabi pa sakin machine shop ang only solution. kailangan palitan head gasket...8k ang quote!
    Nov 2003
    your only problem is depending where the hole is situated, baka di mo maabot ng hand tap. you might really have to pull out the engine and do the tapping on an engine stand.
    goodluck!
    Dec 2007
    ang tanong diyan, which side ng block ang may problema. but if its easy to reach, then you can drill/re-tap it with no problem, while the motor is in the car.
    anywayz, maluwang naman ang engine bay ng Accord. specially if its a 4 banger. pero pag de-sais.. ewan ko nalang. lolz!
    aite, peace.
    Jun 2007
    sirs, meron na po dito sa pilipinas itong TIMESERT Universal Head Bolt Thread Repair kit?
Engine block problem
