Results 1 to 10 of 32
- Nov 2002
- 82
January 18th, 2003 06:32 AM #1MGA PEEPS TOTOO NA PALA ITO DAMI NA KASING CAR DITO SA AMIN SA CAVITE NA DI PUMASA SA EMISSION TESTING NG LTO NA HINDI MAKAREGISTER ANY EXPERIENCES AND ANO GAGAWIN KO KUNG DI DIN AKO PUMASA MATAGAL PA NAMAN NUMBER 8 AKO E ???
January 19th, 2003 01:29 AM #2
if your engine is still using a carb, i-sakal daw yung carb when testing so your engine will run lean and give out lower emissions. Dunno if its effective though.
January 19th, 2003 02:22 AM #3
Just have your engine tuned-up before the registration. It will suffice. Pag alaga po ang engine siguradong it won't fail you. Goodluck. :D
Tsikot Member Rank 3
- 400
January 19th, 2003 11:17 PM #4The objective is for the car to emit clean exhaust gases.
Yung temporary solution tulad ng pagsakal ng carb defeats
the purpose of emission testing.
Kaya nga ginagawa ito ay para all of us can breath clean
air.
Paayos mo kotse mo para di ito smoke belcher. Its as simple
as that. Huwag na nating palusutan ito. Para sa atin din ang
benepisyo ng clean air.
- Nov 2002
- 34
FrankDrebin Guest
January 21st, 2003 09:00 AM #7
pag naka aftermarketin intakes ok lang cguro. pero pano naman yung nka headworks? naku yari yung mga nka injectors....cgurado rich ang gas nila...
- 290
January 21st, 2003 04:27 PM #8diba 90 pesos na lang ang bayad ngayon? pwede naman yata magpatest kahit malayo pa rehistro if you're in doubt of your car. in that way, alam natin kung ano pa ang dapat gawin para pumasa. heheheh i mean ano ang dapat ayusin sa kotse para passing number ang result.
saan ba kaunti lang ang pila?
TJMaxx, saludo ako sa sinabi mo.
January 21st, 2003 04:56 PM #9
I had my 4d56 tested kanina. Hehe ala ako magawa so tiningnan ko kung papasa siya (july pa ako due for registration by the way). Here's a list of what i did:
1. Cleaned my air filter
2. Cleaned my muffler/exhaust via "gripo"
Ang passing rate po for a normally aspirated engine (diesel) ay 2.5. But for new vehilces as of january 2003, 1.2 po ang passing. My engine got a high .88!
Subukan po muna ninyo ipatest..lets not cheat on the process. :wink:
January 21st, 2003 05:34 PM #10
dapat lang!
para luminis naman hangin sa pinas!
susunod na ung akin!
patay..:mrgreen:
I hope the PH government will one day remove all the traffic management responsibilities in the NCR...
SC (temporarily) stops NCAP
