Results 1 to 11 of 11
    Aug 2004
    nagpalit na kanina yung bayaw ko ng MAF sensor, nagpalinis na kasi sya ganun pa rin, bagong palit na din ang air filter.. tumitirik pa rin pag matagal ng dinadrive.
    Ano kayang problem nito? Sirain ba talaga ang Ford Lynx?
    pasingit lang po. do you just spray it with WD40 no need to touch or wipe it?
    This is the two thin wires around 1/4 inch wide one ontop of the order (one shorter)that is in the middle of the air chamber after the air filter. could this also be the reason why rpm hunts in some engine?
    Zdre wulf - nice explanation pang masa ang dating.
    hyperthread - di kaya sa ignition coil ang problema niyan?
    Aug 2004
    Ay sus... Lynx pala!
    Have them check the ignition coils and the cam position sensors. But it sounds like the ignition coil might be the culprit.
    Nov 2003
    yup, kung tirik sa daan then malamang it's one of the 2 ignition coils at fault.
Effect of Dirty Air Filter to MAF?
