Results 1 to 10 of 15
- Dec 2006
- 65
March 25th, 2008 06:02 PM #1Sirs,
Good day to all! First time ko po to seek help here. Anyway, here's my problem as itemized below:
Ride:
95 Galant VR V6
average of 22km of travel per day
averaging 7km per liter of premium/xcs gas
cooling is ok
engine is generally ok
Problem:
1. Oil found on spark plugs 3 to 6, 1 to 3 are ok though.
2. Oil found at the tip of the muffler, pero not that much. Enough lang to darken the innards of the muffler.
3. I lose about half a liter of oil every 30 to 45 days. May tagas.
Actions taken:
1. Had it checked by a mechanic at Petron in proj2. Sabi nya cylinder head gasket daw ang problem.
2. Spoke with a mechanic at speedyfix over the phobe, ang sabi nya valve seal lang daw ang problem.
3. Had it checked at a talyer at san jose bulacan, the mechanic also said na cylinder head gasket nga ang problem, pero recommended to have the engine overhauled.
Just wanted some inputs from you guys to help me decide on what to do.. Many thanks!!
- Dec 2006
- 20
March 28th, 2008 12:28 PM #2You're losing oil and burning it in the combustion chambers. Usual suspects are the piston rings and valve seals/stems. Not likely to be cyl head gasket, as that usually causes radiator coolant to leak out. Overhaul time.
March 28th, 2008 01:08 PM #3
tama si BERNIEDD na dapat pa overhaul makina mo,since wet ng (oil?) ang spark plugs maaring piston ring at valve seals ang may tama. Iyan kasi ang kadalasan pinag mumulan ng pagbabawas ng oil at basang plugs.hindi naman siguro palyado makina mo para maging gas ang dahilan ng basang plugs.
- Dec 2006
- 65
March 29th, 2008 01:48 PM #4
March 29th, 2008 02:55 PM #5
- Dec 2006
- 65
March 29th, 2008 05:47 PM #6i see.. pero let me just clarify - kung valve seals ang problem, i believe kaya ito ng either top overhaul or dukut? and if piston ring, then kelangan na magpa overhaul?
and by the way, nag linis ako ng muffler the other day, then checked it's tip after about 11 kms. found the tip to have cleare moisture, kinda like water pero manipis lang. i just brought up this info to see if it would help with our troubleshooting
March 29th, 2008 05:59 PM #7
AFAIK ang dukot is for the pistons. Pwede mo muna papalitan valve seals then observe mo muna, pakiusapan mo na lang yung mekaniko na kung pwede pag may problem rin yung pistons e mas mababa na sisingilin nya sa iyo. Kasi parang doble trabaho nya kung valve seals muna tapos pistons. IMO sabay mo na lang valve seals and piston rings, antay na rin natin advise ng mga experts kung ano pa dapat isabay.
- Dec 2006
- 65
March 29th, 2008 06:10 PM #8thanks. i guess kelangan ko na mag handa for the overhaul. i;ve read it ranges from 30 to 50k depende sa extent ng sira. i hope yung sa kin nasa base line lang since di naman palyado at di mausok yung makina ko.
i'll be heading to mr. speedyfix's shop next weekend if my schedule permits.
will update you guys about what he's gonna say.
THANKS tsikoteers
Tsikot Member Rank 5
- Nov 2003
- 3,848
April 3rd, 2008 09:01 PM #9if you're not loosing water then malamang hindi head gasket. if there are leaks then that may be the cause of the loss of oil. fix the leaks muna imo then observe again. if the plugs still get wet with oil then have the valve seals replaced muna pero do it on all 6 cylinders para isang gawaan nalang and not just on the 3 that are wet.
- Dec 2006
- 65
April 4th, 2008 06:59 PM #10sir, thanks for your input. tama ka sir, i'm not losing water, langis lang talaga. i had my oil seals sa bandang camshaft(?) replaced nung january - 4 pcs yun i think. nabawasan lang yung tagas at sa ibang portion na ng engine nanggagaling.
question lang po, possible ba na mag cause ng tagas to the extent of dripping na sa floor yung sirang valve seals?
sorry po sir di ako makadaan sa shop nyo may work kase ako ng saturdays lately. open po ba kayo on sundays? do you charge for diagnosis?
many thanks!
Engines also work harder, right?
