Results 1 to 12 of 12
    Pa help naman sa car trouble ko
    car details
    toyota corona carb
    12r engine
    Oil change, air filter change two weeks ago, fuel filter and high tensions wires changed about 6 months ago, Radiator flush and cleaned a month ago.
    I took a a road trip up to laguna about a week ago around 90kms. Got home okay and engine was running okay. On weekends i make it a habit to check my spark plugs para makita kung malinis pa and okay naman ang lahat.
    Today i made a short trip to SM around 20kms away wala naman problema, pero on the way home about half way napansin ko biglang naging 1300 menor ko pero ok pa naman andar pero pag naka stop at idle malakas ang menor at vibration ng engine. Got home okay then checked my spark plugs asap, they were all covered with dry black carbon and the tip of my muffler also had black carbon on it, i cleaned off the spark plugs and sprayed carb cleaner down the carb at naging okay naman ang andar at bumalik sa dati ang menor, di ko pa nata try sa long drive uli at baka tumirik, ano po kaya problem ng car ko? TIA
    Additional info:
    Oil level is okay, hindi nababa, hindi tumataas
    Coolant level is okay pati sa reservoir, hindi naman nagbabawas
    Coolant is clear green, Oil is normal color... no overheating..
    Gas is half full, same gas and gas station lang ang pinupuntahan ko.
    Aug 2004
    Quote Originally Posted by IamJoylucK View Post
    Additional info:
    Black tipped plugs indicate you're running rich. You should have your carburetor cleaned and checked.
    Thanks niky! I hope yun lang ang problema, i read somewhere na puwede rin ignition coil? Ano po ba symptoms of an ignition coil going bad po? TIA
    May 2009
    Wag ugaliing weekly ang checking ng sparkplugs or else you'll destroy its gasket prematurely which can lead to compression problems or you could also cross thread the spark plug hole which is a bigger problem...
    +1 sa sinabi ni niky because due to normal wear and tear. the adjusting screw tip undergoes wear and tear, the reason why we need to regularly tune up engines......hth
    Apr 2010
    Metallic silver ba RT140 mo boss?
    Palagi ako nakakakita ng silver edition dito sa Sta. Rosa baka ikaw yun.
    Anyway, tama sila boss, huwag mo palagi tingnan ang sparkplugs mo. Pa re-timing mo, tapos palit ng sparkplugs. Had a silver edition way back, kaya lahat ng problema mo baka na experience ko na rin.
    Jul 2010
    car details
    toyota corona carb
    12r engine
    Malakas ba magbawas sa oil ang engine mo? Or mausok ang muffler mo pag reach mo ng 80kph. Pa compression test mo engine para malaman kung loose compression or Carb problem. Black or carbon deposit sa spark plug ay sign ng sunog na oil or rich gas mixture adjustment ng Carb. Mas mura pa-adjust or cleaning ng carb.
    make sure your spark plugs has the correct heat range.
    Quote Originally Posted by reym View Post
    Ung unang problem mo, maaring barado ang carb, tama si nik pero it takes two to tango, kailangan mo rin mag palit ng contact point para lumakas ang korienteng pang sunog nga gasolina.
    Ung pangalawang problema mo eh kailangan mo nang pa adjust yung valve tappets mo, yun lang ang iingay jan.
    I'm glad you like the classic 12 r engine. Napakatibay nyan. Kumusta fuel consumption mo sa city and highway?
    Also, masisira thread ng sparkplug sockets pag lagi mo tinaatagal ang plugs..
    Thanks, i got my carb cleaned, i switched gas and they also checked if the sparks were strong at ok naman... Timing was also checked. No more carbon coated spark plugs after that pero still had the weird sound on accelerating.. Napansin ko parang may singaw un exhaust manifold so i got it fixed and test drove it, nawala un weird sound while accelerating pero ako lang un sakay ng car, should i consider myself as "load" while accelerating or do i need passengers, di ko pa na try accelerating with passengers to see if the sound is still there....
    Yeah matibay daw and 12r engine pero matakaw sa gas, 500 pesos roundtrip tagaytay to laguna...
    Quote Originally Posted by Chinoi View Post
    Di naman nagbabawas ng oil.. sige try ko magpa compression test,ty!
    Quote Originally Posted by zero View Post
    I guess they do, i have been using the same brand for a year, ngayon lang naman nagkaganya, ty!
    Malamang pare, kukang ka lang sa babad sa clutch. Mejdo tagalan mo konti ang press sa clutch bago release lalo na kung naka aircon ka.
Dry carbon coated spark plugs HELP!
