Originally Posted by
reym
SOS guys,
My brother has an owner type jeep with a toyota gasoline engine.
He let a shop do the overhauling on his engine.
The camshaft was regrinded, replaced all bearing, placed sleeve, change piston rings, changed valve seat and seals, regrind valves.
Day 1 - Engine is too rough, difficulty in going over a hump. (still managed to at high rpm)
Day 2- Engine still rough (at idle up to 1000 rpm) but has more power, going over a hump is less difficult, engine has no smoke at idle but smokes at more than 1000 rpm (white smoke), exhaust has a smell of un burned petrol.
Day 3- Engine stalled, carb was blocked with something, forced to get home adjusted idle at 2000 -2500 rpm (20 mins drive).
Day 4.- Engine still rough (at idle up to 1000 rpm), power did not improve ,still smoking and un burned petrol fume is still evident from exhaust.
Average daily drive = 5 km per day.
Note: Mechanic did not clean the exhaust pipe.
Any Ideas ??
