Results 1 to 10 of 11
- Aug 2006
- 98
July 20th, 2007 10:05 AM #1Mga bro,
Saan ba makikita ang inaadjust para sa A/F mixture at ano ba itusra nun...parang screw na may spring ba na malapit sa karburador?
How to DIY ang pag-adjust ng A/F mixture?
1) Pano ang pihit kung gusto kong bawasan ang pasok ng gaso?
Kung nakaharap ako sa auto, pakaliwa ba o pakanan ang pihit para mabawasan ang pasok ng gasolina?
2) Pano ko malaman kung nasa tamang timpla na ng hangin at gasolina?
Madalas kasi magcarbon ang plugs ko, some says na rich in fuel kaya nagkakaganun
Stanza ang auto ko, carb type.
Thanks
BANNED BANNED BANNED
- Jul 2003
- 2,267
July 20th, 2007 11:19 AM #2bru,
as per memorandum of the moderators, you can use the search function to look for answers to your question.
i am sure you can find some threads that can answer your air/fuel mixture question.
peace!
July 20th, 2007 10:00 PM #3
Wala bang help desk tapos post na lang ang link? minsan tamad na rin ako mag hanap sa mga old thread.
July 20th, 2007 11:48 PM #4
Gusto ko din malaman to, peru eto lang yung thread na nakita ko...
http://tsikot.yehey.com/forums/showt...r+Fuel+Mixture
I'm not so surprised most tsikot racers don't want to share their personal experience...
July 21st, 2007 05:53 PM #5
that is the screw usually located at the back of the carb.
clockwise po if you want a lean mixture (bawas gas) and counter clock wise if you want to a rich mixture (mas maraming gas).
to eliminate guesswork, you can go to your nearest emission testing center and makiusap ka sa attendant na isalang ang ride mo for emission, bigyan mo na lang ng pangmeryenda. co and hc reading will tell you if your mixture is good or not.
it should not exceed the minimum passing rate nila. pag mataas ang reading just fiddle with the said screw while looking at the machine output until you get the right mixture.
just make sure that the emission test center you go to has a properly calibrated machine.
HTH
- 3,790
July 22nd, 2007 03:17 AM #6I posted this way back in 2004 in this thread -
http://tsikot.yehey.com/forums/showt...burator+tuning
edited a few info (those in red are currently added)...
November 3rd, 2007 11:36 PM #7
i should try this i one. sobra lakas ko sa gas ngayon. dati yun 12 liters ko can reach up to 120kms or more. ngayon 60 to 80kms na lang.
- 3,790
November 4th, 2007 12:52 AM #8before trying it out...try to do a compression check ng oto mo. pagmay singaw at merun ng sira ang piston, lumalakas din ang consumption --- this is assuming that you don't change any of your driving habits nuon at ngayon.
note that if paglagi ka ring natatrapik or running on idle ang sasakyan pumapangit din ang fuel consumption
November 4th, 2007 02:03 AM #9
- Aug 2010
- 11
The current gen Kicks e-power is basically a compromise, as the body+chassis design came first...
2025 Nissan Kicks
