Results 401 to 410 of 2348
- Sep 2006
- 1,335
October 4th, 2008 09:52 AM #401Sir DD,
Can the product Prestone Fuel Injector Cleaner be applied to a diesel vehicle (mine is a Starex '99 A/T TDIC), or pang-petrol gasoline lang? Manufacturers normally state their product's application guide on their label. This should be followed.
For maintenance purposes, would you recommend using cleaners on your fuel system? I can't comment on this as I've haven't had much experience on using fuel system cleaners.
How would you know if the injector nozzles need cleaning na? Cleaning may sometimes work on waxed/carboned nozzles. But no amount if cleaning will fix a failed nozzle.
What are the symptoms? Fuel knock or rough idle are symptomatic of nozzle failure. Black smoke is sometimes caused by faulty nozzles.
- Jan 2008
- 15
December 10th, 2008 05:22 PM #402Curious lang po. Bosch po ba ang fuel injectors ng Carnival 99 model?
bakit po kaya me pagka mausok yung carnival ko pag naka reverse compared kung naka drive forward (e.g. at 1st gear)
thank you
- Sep 2006
- 1,335
December 11th, 2008 12:13 PM #403
December 12th, 2008 12:11 AM #404
- Sep 2006
- 1,335
December 13th, 2008 09:32 AM #405
December 14th, 2008 09:18 AM #406
Sir Diesldude I would like to ask what would happen if you advance the injection timing? any benefits from doing so?
- Sep 2006
- 1,335
December 14th, 2008 10:46 AM #407Diesel injection timing is determined by the factory as the optimal setting for a specific engine model, and is expressed in "degrees before top dead center", example: 20 degrees BTDC. This means that fuel STARTS to inject during the engine's compression stroke at 20 degrees before the piston reaches its topmost position.
Advancing timing by 1 or 2 degrees may not have any noticeable effects. But a large deviation will apply excessive load on the engine, and result in poor engine performance, overheating, smoke, and high fuel consumption.
Your question was good. This topic is very important to all diesel users. We can go deeper into this matter if needed.
December 14th, 2008 08:46 PM #408
But Sir I would like to ask wouldn't advancing the timing a little bit make your fuel burn more completely because it will have more time to mix with the oxygen molecules? Because a mechanic friend of mine told me that if I advance the timing of my injection pump I would substantially improve upon my BSFC and lessen my emission, but also said this would be at the expense of more noise and clatter. Is this true?
- Sep 2006
- 1,335
December 15th, 2008 12:49 PM #409But Sir I would like to ask wouldn't advancing the timing a little bit make your fuel burn more completely because it will have more time to mix with the oxygen molecules? You may be right about giving more time to mix fuel and air, but advancing timing has a downside to it.
Because a mechanic friend of mine told me that if I advance the timing of my injection pump I would substantially improve upon my BSFC and lessen my emission, but also said this would be at the expense of more noise and clatter. The term "a little bit" is quite vague. It would be good if your machanic knows how many degrees he intends to advance timing. 1 deg. advance from manufacturer's specs may not show any noticeable effect. But as timing is more advanced, change will be more noticeable as the engine's performance will detriorate.
Is this true? This is not true.
I will try to prepare a brief description of diesel injection timing for you soon.
Medyo bz lang ako ngayon. Bye....
December 15th, 2008 01:36 PM #410
Substantially improve BSFC?! On a normally aspirated engine?
Baka nalilito kaibigan mo. If you want to burn more completely your
fuel then you have to provide more air. That cant be done by advancing
your injection timing.
With a turbo charger you can have more air.
With a supercharger you will have more air.
Mapapahamak ka lang dyan. Una Mali.
Pangalawa hindi sya nag design ng makina mo.
Pangatlo nalilito sya.
Pero kung gusto mo talaga subukan giving more time to air
to mix with your fuel, tanungin mo mechanic mo kung baka mas maganda
na i polish ang loob ng air intake manifold at lahat ng dadaanan ng air mo para mas mabilis makapasok ang hangin sa combustion chamber at mas madagdagan ang time nya sa loob para mag mix. And baka mas marami na air ang laman ng combustion chamber.Last edited by mark_t; December 15th, 2008 at 02:16 PM.
Yung extra AUX Fan is useful sa mga naka montero. Mag improve daw yung AC system since may extra...
