Page 1 of 2 12 LastLast
Results 1 to 20 of 23
    hey guys. i recently had my PMS.
    ito ay para sa xwind. usually, before nilagay ko 4.5 liters lang. pero now sabi sa akin ng shop na 6 liters daw dapat ilagay ko para sa 2.5L engine. eh una 4 liters lang binili ko. napabili pa tuloy ako ng extra 2. so bale 6 na lhat. nung nilagay 6 liters.... sobra pala! its way over the measuring level. mga half inch more.
    so guys, ok lang ba ang sobra sa engine oil?
    sayang nga eh. nanghihinayang ako. ang binili ko pa naman ay Petron revX all terrain * 274/ea. lumaki tuloy gastos ko.
    It's bad because it will cause the oil to foam resulting in less lubrication than if it was at the correct level.
    NO!!!!!
    Subukan mo uminom ng foam ng frappucinno. Nakakawala ba ng uhaw? Hindi, diba. Kasi puro foam lang. Ganon ang nararanasan ng makina mo ngayon.
    hala! how can i drain about 1 liter?
    Jul 2003
    Actually if its not too much, i dont think it will harm your engine. I usually put more oil past the dipstick on my trick FJ, this to have more oil when i'm driving at extreme angle.
    If you want to drain it, just remove the drain plug under the oil pan.
  7. #7
    Which Isuzu casa recommended that??? Inteco ba yan? I suggest you let them drain the excess, and refund your money.
    OT: "i recently had my PMS." -- doesn't sound too good. Images of my cranky wife suddenly flashed before my eyes... ;)
    The answer to that DIESELNUBI
    Like LORD OTEP and LORD GLENN said " NO "
    4ja1 ENGINES pag di palitin ang oil Filter can go as high as 5 liters pero pag 4 Liters pwede na yan
    I drain mo tapos... throw it in there face.... hehehehe
    bad! talaga itong is boknoy! hehehhe
    pansin ko pag sobra langis ko mas mausok sya kesa dun sa me bawas ng konti sa full
    Lunod ang makina, mahihirapan lalo umandar. Just follow the drain plug procedure and estimate a liter off.
    Like I always say.... there's a reason why the MAXIMUM level is called MAXIMUM
    18Dec2003 (UTC -8)
    Ig grossly over-filled, yes, it's bad for the engine. Drain it, if you value your engine.
    But if it's just a little over the "full" level, then it'll be fine. The diesel engine will just consume the excess.
    How did you fill it up anyway? One should fill, measure, fill, measure, until satisfied.
    Your oil seals will hate you for it
    hindi naman sa isuzu casa. sa Goodrich located * araneta ave. near BigBerts ko pinagawa. ewan ko nga ba kung baket ndi pa ako natuto?! dati we had FX aircon fixed dyan. nasira dahil maling freon nilagay. "pwede rin daw"
    make that 2 cars! nung corolla ko dati nasira rin aircon dahil sa kanila.
    okay na guys... i just asked our 'boy' to drain some oil out. kumuha pa ko ng 1 liter na tabo para ma tancha ko. tinago ko ung 1liter para next pms ko saka ko gagamitin.
    pero ung oil ko above MAX parin. but konti lang. okay na siguro noh?
    sabi nung gagawa, 6 liters daw. pumunta ako sa owner to verify... 6 liters din daw! sayang napabili tuloy ako extra 2 liters.
    ndi ko kasi aakalain na pati ba naman change oil n filter lang eh papalpak pa sila.
    OT! Paolorenzo!
    grabe oo nga eh. nung nabasa ko ulet ung post ko. napa dalawang isip ako nun ah! parang may mali sa grammar. hahahah
    anyway, a few good laughs wont hurt anyone! pasko naman eh!
    MERRY XMAS EVERYONE!
    A little above the max mark is ok. Your engine will consume that in weeks time. Btw, check your oil after couple of days after draining to see if the oil is enough.
    di ba 6 liters ang kailangan ng engine ng XUV? i took my XUV sa casa for its PMS, they put in 6 liters of oil in the engine.
    check ko yung manual mamaya to see if 6 liters nga ang capacity ng engine.
    lagot ka!
    kelan pa yan? tgnan mo dipstick mo!
    Yup..oil seal failure and leakage.
    correct. the problem with filling the engine with oil above the MAX level is that it WILL put too much pressure on the oil seals.
    Yup, you guys are correct that the excess oil will get consumed, but isnt this a symptom of a blown engine? Oil forcing its way through the piston rings? If thats fine with you then by all means overfill your crankcase. Safe naman kasi while between the min and max markers of the dipstick. i see no reason why go over it.
    isa pa ulit na "NO"....
    next time pa change oil ka....pagkatapos ikabit ang bagong oil filter, lagyan ng recommended na liters of engine oil....tingnan ang dipstick...kapag nasa max level na paandarin ang makina ng 2 minutes...patayin ang kanina...maghintay ng 5 minutes at tingnan ulit ang dipstck (meron nang laman na langis ang oil filter mo kaya mababawasan level nito)....maglagay ulit ng langis kung kailangan ngunit hwag lalagpas sa max level ng dipstick...
pwede ba ang sobra na engine oil?
