Results 1 to 7 of 7
October 15th, 2006 06:03 PM #1
kung naagapan naman eh ok lang yun , yung sinasabi ko kasi eh yung tipong talagang xtreme na overheat na hours na nag ooverheat :D hopefully ok pa yan makina mo sir :D
October 15th, 2006 08:05 PM #2
if the engine stopped due to overheat then the head gasket would be broken, but as you mentioned naagapan naman, so meaning nag increase lang temp and the engine was still running. to tell whether the head gasket is busted is to run the engine cold and open the raidator cap fill it with water if lacking and observe if the water is being ejected from the radiator opening. yes tama ka tatagas ang water pump if broken na. If I were you drain all water/coolant first, change the rubber hoses all of them, refill with new water/coolant combination and observe.
October 16th, 2006 10:50 AM #3
sir yung bubbles na sinasabi ko eh yung bubbles na enuff na mag spout out ng tubig. anyway di mo naman siguro magiging prob yun kasi naagapan naman pala sir eh :D happy motoring
someones are (at last!) loudly asking, "why did they turn off the countdown timers?"
SC (temporarily) stops NCAP
