Results 1 to 10 of 22
- Oct 2006
- 34
October 14th, 2006 11:31 AM #1Ilang Kilometer Reading Ng Odometer Bago E Change Ang Gear Oil Help Sir Otep
October 14th, 2006 12:42 PM #2
Check your manual. Sa Besta sobrang dalas, every 20,000kms. Dun sa ibang sasakyan minsan every 40,000kms lang.
October 14th, 2006 01:49 PM #3
according to my Dmax manufacturer's manual (which is different from dealer's PMS) every 40,000 km. puede rin every 30,000 km. just use the right classification of axle oil with proper selection of viscosity. if you are using FUEGO, it might be GL-5 class with SAE of 90 or 140. for my '94 model isuzu pick up, i use SHELL SPIRAX GL-5 with SAE of 140. The SAE 90 works in the MAXIMUM temp of 37 deg C ambient or surrounding temp...
October 14th, 2006 02:02 PM #4
to be safe, around 20,000 kms..... para parati advance ka sa wear and tear ng gears... huwag mong patagalin kahit city driving lang kc meron din life span ang oil....
2dmax-- our dmax is rily at 20,000kms and thats recommended by the plant... hindi talaga masunod ang nakalagay sa engine or hood kc its would differ from climate of one country to the other... so we shoudl follow the recommended change oil interval stated by the casa kc yun ang pinapagawa ng isuzu plant... i use PITTPEN gl-5 85w140... its a multigrade differential oi...
October 14th, 2006 02:05 PM #5
kung sa fuego, its 20,000kms... with gl-5 140 grade.... and the trans is an engine oil if manual trans.. A/T is a DEXRON III... better punta ka nalng ng casa tukong.....
- Oct 2006
- 34
- Oct 2006
- 34
October 15th, 2006 10:12 AM #8
im interested ano nga pala mang yayari pag di napalitan ung gear oil ? have anyone of you experienced any bad things that hapend due to it ?
October 15th, 2006 10:49 AM #9
- Oct 2006
- 34
October 15th, 2006 11:54 AM #104wd Po!!! Pano Po Kung Di Mu Mapapalitan Ang Gear Oil Masisira Po Ba
IIRC they're with AVID. The reported numbers in the TG article are from CAMPI.
Car Sales Data (2024)
