Page 2 of 4 FirstFirst 1234 LastLast
Results 21 to 40 of 99
    there is always a compromise. maximum protection means fc is not the best.
    recently had fe oil over longlife oil.. i change frequently anyways so i dont need that ll oil.
    fe oil was also cheaper than the ll oil..
    Feb 2017
    Thanks sir! Naghahanap talaga ako. Delo 400 lang talaga ung nakikita ko. Sa Lazada lang ung may 400 mgx
    Kelan kayo nag change oil pag ganyan? Ako kasi 5000kms pa din eh.
    PAJ 4M40 MORE POWER!
    Oct 2015
    Quote Originally Posted by 94mitsukid View Post
    5000 kms pa rin saken sir, maitim na rin ang langis, at tsaka napakamura na para tipirin yung pag changeoil.
    Feb 2017
    Quote Originally Posted by kircchoffs View Post
    Thanks sir! Pertua kasi dati kong gamit. Hahaha. Performance wise okay siya diba? Sa lazada kasi puro positive pero mas maganda kung sa user ako magtatanong haha
    Mar 2005
    Walang 1liter ng MGX available? 5L lang available sa Lazada. Kulang pa ng 1 Liter hehe.
    Oct 2015
    na try mo na ba sir i mix ang DELO400 sa Pertua? yan kasi balak ko sa next change oil ko
    Sent from my SM-G532G using Tsikot Forums mobile app
    Feb 2017
    Pertua CVO kasi gamit ko ngayon plus oil and metal treatment. Okay naman siya. Sa isa naming auto Delo gold plus Pertua oil and Metal treatment. Walang usok nung nag emissions test. Sana nfa navideo ko para wala masabi haha
    Apr 2012
    The problem sa Lazada walang tig 1 litre
    Sent from my LG-H818 using Tapatalk
    Feb 2017
    Sa selected caltex stations meron daw boss
    Aug 2008
    If meron lang way to measure engine running hour eh doon na ako. Kaya ba ma-read ng ng OBd scan?
    Feb 2017
    Will use Delo 400 MGX for next month's change oil. Will provide feedback once done.
    So excited as first time to use Delo product sa tsikot ko.
    Sent from my ONEPLUS A5010 using Tapatalk
    Feb 2017
    Changed oil using Caltex Delo 400 MGX. Initial impressions:
    1. Responsive pagdating sa acceleration
    2. Tahimik ng engine
    3. Mapapangiti ka na lang kasi feeling mo tuwang tuwa ung sasakyan.
    Will see if this is better than my previous oil (Mobil Delvac) and will see how the car runs at 3.5k kms up to 5k kms
    Feb 2015
    If I may ask sir, on what vehicle did you use it? Thanks.
    Feb 2017
    Quote Originally Posted by makelovenotwar View Post
    Pajero 4M40 engine po. [emoji16]
    Jul 2017
    Currently using this on my 2017 montero, change after 5k. Do you recommend this or full synthetic every 10k? My unit is gonna hit 10k soon
    Most of the time only city driving, but occasionally I go on long drives.
    I appreciate your suggestions!
    May 2017
    I switched to Delo 400 MGX for my 2016 Dmax since I got 35k.
    Now 56k and engine running very good.
    The new Delo 400 is as good as some semi synthetic oils. It's very good for egr and DPF fitted diesols.
    You won't get sludge provided you change oil regular and hardly any carbon build up as this oil has great protective and cleaning additives. And it can handle the heat better than most other mineral oils.
    But I always change oil at around 5k regardless because even if your using 100% synthetic oil the dirt is still their circling around inside your engine,. I dont like long oil changes that's why I use mineral oil so I get the dirt out sooner.
    Yes you can get 10k from fully synthetic oils but the longer the oil stays in the more dirt you will have inside your engine curcling around. And even though fully synthetic oil take longer to break down than mineral oil you still have suspended dirt flowing inside your engine longer.
    For modern SUV and pick ups in the Philippines you can't go wrong with Delo 400 MGX As long as your vehicles Manuel says it's ok to use 15w-40 weight.
    My manuel says Delo 400 is ok to use so I use it
    I don't use a catch can or block the egr as many others have done.
    Bottom line is if you want your diesol to last then remember the 3 basics
    1 clean oil...regular service.
    2 clean fuel.....fuel filter replace every 10k even if you have a pre filter.
    3 clean air.......I clean air filter every 5k and replace every 20k.
    God Bless You
    Jun 2010
    Pwede rin po ba sa Innova Diesel D4D yang Delo MGX?
    Sent from my SM-T285 using Tapatalk
    Feb 2017
    Quote Originally Posted by rowmann1223 View Post
    Inaantay ko na lang iyung na-order kong baldwin filter, then ito na ipapalit ko sa Innova ko..
    Saan available iyong delo 400 mgx? And for how much?
    Caltex/Chevron stations. P1452 5litre jug.
    The older Delo400 is now phased-out as per the store manager
Delo MGX 80,000km OCI
