Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
    Feb 2005
    Diesel ba van mo? Baka kinakabagan lang meaning may hangin sa fuel line. You can try i-bleed fuel line mo thru the injector para mawala hangin.
    sir wax,
    carburetor po ang van ko.
    Feb 2005
    I see. Possible that you have to change your fuel filters. You can also try to have your carburetor cleaned or serviced baka kasi nagbara sa loob.
    Dec 2004
    in my case, nagpalit lng ako ng fuel filter den back to normal na. :D
    Dec 2004
    Sep 2004
    check your air filter, ignition timing, tire pressure, spark plugs & wires. also your carburetor might be running rich or has worn jets.
    Jun 2005
    I suggest you try the accetone trick. Same din kasi tayo ng problem before & the accetone did the trick & the good thing is halos wala akong nagastos.
    Jan 2003
    kung plastic lang fuel filter mo, di ba mura lang yon?
    i believe wala pa 500p? so mura lang magpalit
    ok na mga bro! pina-vacuum ko lang yung fuel filter.
    Yung mabigat na takbo nya, the mechanic told me about the angle of the contact point. Ano po dapat adjustment for Vanette?
    Jan 2003
    pano vacuum ang fuel filter?
Decrease in fuel efficiency after experiencing depletion of fuel
