Results 1 to 20 of 25
    Oct 2008
    Can you guys give me advice..
    Some 3,500 kms after an oil change, the oil on my 3.2 strada is quite dark brown already. But the oil of our diesel innova with a similar mileage after an oil change is still light to medium brown. Both use the same oil (15W-40 Castrol GTX Turbo Diesel)
    Is this a cause for concern?
    The oil getting dark on a diesel is normal, heck after driving it home from a fresh oil change in the casa it could already be black. What I'd like to know is how long the oil should stay in the engine (actual kms driven vs actual running time). Does anyone know if Caterpillar still does EOA's?
    Mar 2005
    +1 Pag uwi ko galing PMS ng montero pag check ko dark na ulit yung oil parang hindi bagong change oil
    Oil getting dark is normal as this means it is absorbing the dirt of your engine. IMO, its even more of a cause for concern if it doesn't get dark as you'll wonder where the dirt goes. the rate at which it changes color will also differ between engines/brands.
    * TS: Try mo sir yung Shell HX7 Diesel next time. Mine has 1,000kms on it and not yet dark colored compared to using multi-grade oils. Just a suggestion. Mas malaki rin kasi at mas malakas engine ng 3.2 TDic CRDi vs 2.5 Turbo CRDi kaya malamang mas maraming soot and carbon deposits IMO.
    Dec 2007
    You might want to try a quality oil filter like Baldwin or Fleetguard that have much better filtration and higher dirt holding capcity over OEM. I would also add a oil catch can.
    Quote Originally Posted by Zhandros View Post
    Actually, I'd be more concerned about the diesel Innova here.... Engine oil getting dark in a diesel engine means that it is doing its job of floating the deposits in your engine.....
    Any comment from the diesel Innova owners?
    13.0K:funa:
    Dec 2007
    13.0K:funa:
    Good oil will do the job to keep the soot particles suspended in the oil, But it's the filters job to remove those particles. suspended soot particles cause tons of wear in your engine. Just because you have a diesel does not mean your oil needs to be pitch black. If you have a filter that can clean down to 10 microns then it will be fairly dark brown. If your running something like a VIC or OEM Toyota you can for get it because they can only get the job done effectively down to around 25 microns. VIC's don't touch particles in the 20 to 5 micron range.
    If your past a your warranty might as well run a filter designed for heavy duty fleet use, IE. it gets the job done to keep your engine oil clean. Not to mention they hold up to 3 times more particles before becoming clogged. Cheap filters die early and just go into bypass mode so they just re-circulate dirty oil.
    *dvldoc
    Maybe we've just all been used to seeing black oil in our rigs before 5tkms on the oem filters lol. Gonna give Fleetguard a crack next oil change.
    if medyo OC ka and money to spare... bili ka ng 1-2 sets of oil (yung cheapest you can find) use it for flushing purposes...
    drain used oil
    then replace with cheap oil
    run the engine
    drain the oil again
    case to case basis if you need a another set for flushing... pero kung religous naman ang change oil nyo sir, kahit 1set lang
    then replace with your preferred oil
    tried this once, and dami natangal na deposits... matagal bago dumumi ulit langis.. parang brand new yung appearance ng oil sa dipstick
    Dec 2007
    *dvldoc
    Get the LF3487 For the Navara, It's bigger than stock and is the full sythetic media and will filter down to 2 microns. They are less than 600P.
    Your oil will defintetly clear up using these. If you haven't done a flush do it prior to the oil change.
    That's the plan, problem is the local stores only carry the LF3400. Maybe you could take a leave so you could go back here for a vacation and we could get some? Kidding.
    Apr 2009
    haha, baligtad ang inaalala mo. yung Innova ang magtaka ka.
Dark engine oil
